Drive Shaft
Old Feb 2, 2015 | 04:52 PM
TAPyvehc93's Avatar
Default Drive Shaft
I have heard that these drive shafts on the 2wd NNBS CC/EC like to let go at around 100mph. Could I just get the stock one high speed balanced and be okay?
Truck has a trick turbo kit too.
Old Feb 3, 2015 | 12:41 PM
Suburbazine's Avatar
Actually needs to be bigger diameter or split into two pieces (or made of a different material). The problem is the physical material reaches a point where centripetal force causes a harmonic wave to ripple the length of the shaft. When you hit a certain speed above 107-111, the ripple reaches a critical peak at a single point and the driveshaft shatters.
Simply balancing it won't help you much due to the design of a driveshaft.
GXPJAY
Feb 13, 2022 08:15 AM
Blue03sss
Mar 7, 2019 05:06 PM
Zacholcomb
Sep 3, 2015 06:14 PM
Ketis
Jul 23, 2015 12:37 PM
