Drag Race Light-Weight Control Arms
Old Dec 22, 2015 | 07:04 PM
Crazycanuck's Avatar
Originally Posted by Blown06
Yes, it is for a coil over shock. Ridetech makes a shock that bolts in using the factory upper mount, but it is not a drag type set up. The valving on the shocks is for the street along with the super heavy spring rates.
What would you recommend ? I am not afraid of spending some money to get this right. Some type of qa1? I read your build thread and what prompted you to go with a coil spring instead of a coil over like what I am looking at setting up ?
Old Dec 22, 2015 | 11:49 PM
Blown06's Avatar
8 Second Truck Club
I am running a coilover. You may have me confused with someone else. Especially if your telling me to help you spend money. lol
Old Dec 23, 2015 | 05:04 PM
I am looking at something along the lines of this
http://www.ridetech.com/store/1999-2006-chevy-silverado-strongarms-shockwaves-front-lower.html
And
http://www.qa1.net/suspension/street-performance-racing-shocks-struts-and-pro-coil-systems/front-pro-coil-shock-systems
Will these work together in some sort of way ? I can weld and fabricate not problem (I do it for a living) and I can make new mounts for the upper and lower coil shock mounts.
Old Dec 23, 2015 | 11:14 PM
Blown06's Avatar
8 Second Truck Club
If you can weld and fabricate and do it for a living and can make mounts then I'm a little confused why you're asking the questions you're asking.
Fabricators make **** fit. It's what we do.
Old Dec 24, 2015 | 02:26 PM
That's true, I'm good with a welder, just not at ordering parts lol. What front shock are you running ? They are qa1's right ?
Old Dec 25, 2015 | 12:42 AM
Blown06's Avatar
8 Second Truck Club
I used to run qa1's with the stock mounting points. I now run a custom set of Afco's from Menscer.
Old Dec 25, 2015 | 08:02 PM
slowswb's Avatar
Hit up Vic VA Specialties on facebook he makes light weight chromoly ones with ball joints for like 850
RaceReadyPerformance
Nov 18, 2015 01:39 PM
Eduardo Perez
Nov 14, 2015 09:37 PM
slowec
Oct 30, 2015 08:40 AM
gallo-lo
Oct 25, 2015 01:15 AM
