Drag Race Light-Weight Control Arms
Old Dec 13, 2015 | 01:44 PM
Crazycanuck's Avatar
Default Drag Race Light-Weight Control Arms
Hey,
Looking for some light weight upper and lower control arms along with a spindle for the front of my truck. Truck is still a DD so I don't want to go down in the front more then I have to. I have a 4" drop in the rear with stock springs (for towing purposes) Caltracs, small tire, stock 10 bolt with moser axles. So I am looking at a 2" front drop at the most, I just can't seem to find a decent front suspension for a drag race application. I know this will help me get my 60' times down a little more considering the whole front end is stock other then a removed sway bar.
06 chev 1500 RCLB, turbo 5.3l
Best 60' 1.62
Old Dec 13, 2015 | 02:09 PM
George C....'s Avatar
Formerly ScreamingL
My DJM upper and lowers dropped 14lbs over my stockers
Old Dec 13, 2015 | 02:31 PM
blown02408's Avatar
02 w/ lowest mileage 2800
Not sure how that's possible, when I weighed them there was only a pound or two difference.
Old Dec 13, 2015 | 03:32 PM
Formerly ScreamingL
Well telling ya what mine weighed in at
Lowers saw the big difference
Not hard to believe a set of arms dropping 7lbs each side going from a cast setup vs tubular
My arms also dont have the sway bar mounts which is unneeded weight
Old Dec 13, 2015 | 11:45 PM
Blown06's Avatar
8 Second Truck Club
Ride Tech's will get you around 15-17
Old Dec 14, 2015 | 12:28 PM
TrendSetter's Avatar
I think TRZ has an option that uses a gen1 camaro spindle/brakes. its not a catalog item but it might be worth a phone call to them
Old Dec 16, 2015 | 07:09 PM
Which lower arm works with a coil spring ? There are 2 lowers listed on ridetechs' site.
Part #11381499
Part #11382899
Old Dec 17, 2015 | 01:16 AM
Blown06's Avatar
8 Second Truck Club
The ones that save the weight don't use the factory style coil spring.
Old Dec 20, 2015 | 04:13 PM
Do they use a coil over ? Ride techs site has very limited info on them. One looks like an air bag would bolt to it (as it has a "base" with a mounting hole) and the other looks for a coil over.
Old Dec 21, 2015 | 12:17 AM
Blown06's Avatar
8 Second Truck Club
Yes, it is for a coil over shock. Ridetech makes a shock that bolts in using the factory upper mount, but it is not a drag type set up. The valving on the shocks is for the street along with the super heavy spring rates.
