Does GM make different leaf springs?
Old Jun 21, 2008 | 12:39 PM
KevinF56's Avatar
Default Does GM make different leaf springs?
I was down visiting GMracer last night, dropping off some door panels for him, and we were looking at our trucks.
His: Bone stock 1999 2wd
Mine: 2004 4x4 lowered by removing lift blocks and 2" shackles (as well as turned out the torsion keys)
Here's the problem: his truck is easily 2" lower than mine in the rear. Technically I should be 2" lower than him because I have shackles, but I'm not. Now, my tires are bigger than his, but it shouldn't cause that much of a difference.
We then looked at our RPO codes...
Mine: Z82 : TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.0.
His: Z83 : CHASSIS PACKAGE, SOLID SMOOTH RIDE
Are my leaf springs different than his? Are they sprung higher?
Old Jun 21, 2008 | 10:33 PM
hirdlej's Avatar
Count tge leafs, my dad's 97 c1500 work truck has 4 leafs for his trailering package, my truck is a smooth ride susp package and I only have 3 leafs.
Old Jun 22, 2008 | 02:02 AM
KevinF56's Avatar
i have 3 leafs; 2 leafs and an overload. here is a picture of my current set up:
Old Jun 22, 2008 | 01:11 PM
His might have sagged alot more due to being 5 years older...plus it seems the '99-'00 trucks all sag in the rear, both 2/4WD. I have my blocks removed and when I'm on stock 265/70/17s I'm still sitting higher in the rear than most stock '99-'00 Z71s...most of them sit at SS height or even lower it seems.
Every '99-'06 1/2 ton truck I've seen has the 3 leafs...I always thought the leafs were all the same between the 2/4WDs, the 4WDS got the 2" blocks for height and obviously all trucks got diff. shocks depending on what susp. pkg.(Z85, Z83, Z71, etc)
Old Jun 22, 2008 | 09:29 PM
dlstewart01's Avatar
Z82 does not have any thing to do with the springs, that a trailering RPO.
You probably have Z85 suspension. That the heavy duty suspension thats normally used with the Z82 option.
Don
Old Jun 22, 2008 | 09:34 PM
agreif's Avatar
What's HD about the suspenion to make the packages different?
Andrew
Old Jun 22, 2008 | 09:41 PM
Most of the 2 wheel dr trucks have Z85 suspension. If you look up that RPO code it will say heavy duty suspension. I would say the springs are a little stiffer. The smooth ride suspension will squat more under load.
Don
Old Jun 22, 2008 | 09:43 PM
KevinF56's Avatar
yeah i do also have the Z85 suspension.
Old Jun 22, 2008 | 09:45 PM
I just looked the RPO code Z85 up and it says increased capacity.
Don
Old Jun 22, 2008 | 10:49 PM
00Silv4.8's Avatar
I would think that u have more springs than he does being a Z71?
