does anyone have one of these laying around?
Old Oct 19, 2007 | 05:43 PM
Superado's Avatar
11 Second Truck Club
Default does anyone have one of these laying around?
VBP-VAC
For trans’s with vacuum modulator and Supercharger or Turbo
Vacuum/Boost Bypass Kit: All trans with vacuum modulator and supercharger or Turbo. Prevents boost pressure from causing runaway line pressure.
OR is there something else that does the exact same thing that I can use?
thanks!
Old Oct 19, 2007 | 05:55 PM
CHEVRACER83's Avatar
Originally Posted by Superado
VBP-VAC
thanks!
WOULD AN INLINE CHECK VALVE WORK??
EDIT... NEVERMIND... JUST THOUGHT ABOUT IT AND IT WOULD HOLD THE VACCUM AND NOT CHANGE..
Old Oct 19, 2007 | 06:05 PM
adam1803's Avatar
I just happen to have one, PM me if you want it and we can talk price.
Old Oct 20, 2007 | 08:01 AM
FLT's Avatar
FLT
FormerVendor
I usually have a couple in stock. Keep in mind that if you are running 10psi or more, that installing 2 of these are a good idea. Give us a call if you still need one.
Old Oct 20, 2007 | 11:48 PM
Superado's Avatar
damn...I finally found a close-up pic of one!
i can't believe that can't be made for less than $20
Old Aug 24, 2011 | 08:54 AM
Xmanwes's Avatar
Registered User
Sorry to dig this up. Why would you need two if running more than 10 psi? Isn't the point of it not to push more than 10 psi through the line anyway?
Old Aug 24, 2011 | 05:55 PM
Vince B's Avatar
We had found that in higher boosted combo's that some times we would see boost at the modulator. The second valve really is a safety for the other. HTH Vince
walledition
Feb 24, 2026 03:27 PM
lxcoupe
Oct 4, 2015 08:07 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
EmmerichLSx
Sep 20, 2015 02:09 PM
Trevor.j
Sep 10, 2015 03:16 PM
