Do I Need Different Shocks for the Drop?
Old Apr 7, 2006 | 07:33 AM
Question Do I Need Different Shocks for the Drop?
I'm going with Belltech's 2" front lower spindles and McGaughy's 3.5" rear hangers, shackles, 2* pinion shims, and carrier bearing spacer.
My main concern was having to change to a different rear shock due to the drop.
Do I need to change them or can I leave the O.E. shocks?
Jim
Old Apr 7, 2006 | 07:34 AM
leochevy2001's Avatar
you should be able to use the factory shocks.
Old Apr 7, 2006 | 04:53 PM
Cuerva's Avatar
11 Second Truck Club
Keep the factory shocks till you wear them out, then get shorter shocks.
Old Apr 8, 2006 | 11:11 AM
LS1TRUCKGUY's Avatar
You Will Be Ok With The Stock Shocks, Unless You Tow Anything Or Have Any Weight In The Bed, It Will Bottom Out. If You Tow, I Would Suggest A Stiffer Shock.
Old Apr 8, 2006 | 02:16 PM
IDISAPR's Avatar
Not to hi-jack the thread, but does anyone with a drop & notch setup run adjustable shocks with the leaf spring setup? It may have been talked about in the past and I just missed it, or it may not even be an option. If so what has been used and is somewhat easy on the butt?
Old Apr 8, 2006 | 06:51 PM
Post
I will be adding the Firestone air bags to the rear for towing.
That should fix any bottoming out issues. It bottoms out with the factory suspension if I hit a big enough dip in the highway. There are quite a few of those around the Houston highways!
Jim
walledition
Feb 24, 2026 03:27 PM
06droppedcrew
Nov 17, 2015 10:56 PM
pewter00
Sep 13, 2015 11:14 AM
pewter00
Sep 11, 2015 09:32 AM
