Do do you measure for conveter spacing
Just like the title say. How do you do it??
I just installed a 6L90 converter from a ZL1 in my 6L80 while I had the motor out. I'm getting a very faint grinding while sitting at a light. When I installed it I measured the old converter and it sat back 15/16" from the front of the bell housing. When I slide the new converter in. It slide right back to that measurement.
Did I do it correct or did I mess something up bad?????
you need to measure the spacing between the converter pads and the flexplate.
You chould have 1/8-3/16 clearance.
Using a drill bit shank is an easy way to measure...if it fits, you have clearance...if not, you don't
if you have less than 1/8 the thing will eat the pump
if you have more than 3/16 you're liable for the converter to have poor pump rotor engagement and break the rotor
strutaeng (04-25-2022)
Looks like I’ll park and check it. I hope I didn’t mess anything up.
Well that was a short lived rebuild../././././.
Yea real short rebuild. I almost have 900 miles on it. Pulled a 20 foot car trailer with RZR XP4 around last weekend for about 150 of those miles and didn’t skip a beat.
But now while coasting to a stop you can here it grinding and if you shift it in N without hitting the brakes it will stop making the noise before the truck stops moving.
What Moon Monster said. How did you get a 6L90e from a (Camaro?) ZL1? The 90e just came on the HD 8 lug trucks...
The 6l90 is in ctsv and zl1.
strutaeng (04-26-2022)
