DJM 4/7 drop kit Bumpy, need advise
So I installed the 4/7 over 2 years ago and finally agree with the wife thats it's a little bumpy. Has anyone found a good shock company which could work with the stock coil spring, provide the quality to coast over bumps and correct the tire rub on the bottom of dips. I contacted QA1 and they didn't seem to have the knowledge to help. Thanks for the help.
i imagine after 2 years it could be about time for new shocks. and no one makes a direct bolt in..you could go to a coil over setup but it will require a little work to make it work..and you would probably have to play with spring weights and lengths to find a ride your combination
Are you having the same issues?
there are no drop in shocks that will work with factory coils. i was thinking about going to coil overs but have gotten around to it yet. i imagine you would have about $650-700 depending on what brand you go with.
forklord
May 3, 2016 11:21 PM
Flewbyu123
May 3, 2016 01:26 PM
