DJM 4/6 Drop HELP
Old Apr 25, 2008 | 06:22 AM
knyznyk's Avatar
Default DJM 4/6 Drop HELP
I have a 05 RCSB 4x2 silverado I lowered it 4/6 with a DJM drop kit (flip kit in the back with c-notch and bumpstops in place). When I hit a big bump my rear diff hits the box. Should I cut out the cross beam on the underside of the box over top of the diff? Or are my shock junk? I got the shocks from belltech for their 4/6 drop. Shock are band new as is the drop kit.
Thanks.
Old Apr 25, 2008 | 08:50 AM
TXsilverado's Avatar
stiffer shocks and longer bump stops IMO.
Old Apr 25, 2008 | 09:09 AM
VroomVroom's Avatar
My guess is the shocks are fine - they're just doing what they do. Something has to give when you hit a bump, right? I do like the bump stop idea. Good luck...
Old Apr 25, 2008 | 09:15 AM
SSlammed03's Avatar
post pictures of ur set up and imma compare it to how mine is.. i have the same things but mine is smooth ride in bumps..(most)
Old Apr 25, 2008 | 10:16 AM
02BlueStepside's Avatar
Is your exhaust running over the rear end and hitting when you hit a bump, or is it the actual rear hitting the bed? I think the belltech kits comes with a notch for that bed crossmember, should be able to buy it seperate if you want to notch the bed crossmember. Or you could get longer bump stops like TXsilverado suggested.
While your under there, check that brake line that runs across the top of the housing and make sure it isn't damaged, and then move it down so you don't have to worry about loosing your brakes.
vmaxpro
Sep 28, 2015 11:10 AM
twake_410
Sep 25, 2015 10:09 PM
jpweb90
Sep 17, 2015 06:32 PM
pewter00
Sep 13, 2015 11:14 AM
pewter00
Sep 11, 2015 09:32 AM
