Disc to 05 DRUM ???'S
Old Jan 23, 2012 | 07:06 AM
slowec's Avatar
Default Disc to 05 DRUM ???'S
I want to swap over to a 05 drum set up because I want to run 15' Bogart street strip wheels. I can get the whole rear for pretty cheap, but what is involved in the swap? I searched , but ramdom comments where the best I could find. I know you can grind s-10 calipers down a lot and run a 15, but I want a streetable wheel. Any real world ino PLEASE. Thanks.
Old Jan 23, 2012 | 08:05 AM
TXSZ66AVLANCHE's Avatar
All you need is tp swap the brake lines and emergecy brake cables. I have what you need and will do an even trade .....pm me if interested.
Old Jan 23, 2012 | 08:33 AM
slowec's Avatar
I tried to get some local guys to swap me, but could not so I bought a used 05 rear. THANKS for offering though.
Old Jun 28, 2012 | 06:42 AM
Beatdown Z's Avatar
Laid Back
So just to verify, drum brakes will bolt up to a disc brake axle with no issues?
Old Jun 28, 2012 | 08:32 AM
MPFD's Avatar
11 Second Truck Club
That doesn't sound right, but IDK? Bump for an expert...
Old Jun 28, 2012 | 09:55 PM
pdxmatt's Avatar
The axles flanges are the same, yes. As noted the hardlines and ebrake cables will be different.
Not sure if they will function at 100%, I'm still investigating that part.
Old Jun 28, 2012 | 10:34 PM
JoeGibbSilverado's Avatar
Ive done it, went from drum to disc. Pretty straight forward swap. I bought a complete disc rearend for supercheap and used the hard line from the disc rear, very simple swap.
Old Jun 28, 2012 | 11:02 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You are correct. 1 thing to note is the way the flanges on the housing are clocked. On a disc rear end there tilted at 45 degrees in relation to the pinion. On a drum rear end there parallel with the pinion.
Your best bet is to get a complete set up and bolt it in for simplicity. But just the brakes can be swaped...
As far as function. They will work but they use different pressures. I have only worked with drum to disc conversion. On a drum to disc swap, if you do a panic stop, it will lock up the disc in the rear... So in theory the drums may not get enough pressure and the front's might be working harder...
Old Jun 29, 2012 | 03:17 AM
slowec's Avatar
https://www.performancetrucks.net/fo...esults-503963/
Texas5.3_1251
Mar 5, 2016 08:10 PM
turbo6c3
Oct 5, 2015 06:11 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
Benloe
Sep 22, 2015 10:24 PM
DrX
Sep 18, 2015 08:53 AM
