Diff Case Spreader...
Old Nov 24, 2008 | 11:26 PM
budhayes3's Avatar
PT's Slowest Truck
Default Diff Case Spreader...
...do you need one to install a trutrac into our 10 bolt rears?
Old Nov 24, 2008 | 11:31 PM
Stoichiometric's Avatar
I tried to install mine without one. I ended up breaking the shims trying to get everything hammered back in. I built a case spreader with some 1/2" allthread, 1 1/4" box steel and bolts that I ground to fit in the holes of the case. Worked like a champ.
Old Nov 24, 2008 | 11:39 PM
StrokerAce03's Avatar
I didn't use one and everything lined up ok. Might be good to have access to one though just in case.
Old Nov 24, 2008 | 11:47 PM
Dirty Dave's Avatar
I worked for gm for 15 years and never used a case spreader on a 8.6. I have probably built 100+ 8.6 rear axles and never had a problem. With the trutrac you can usually reuse the original shims in there original location. Be sure to check you're backlash before you take it apart and make sure its the same when you're done, if you're reusing the ring and pinion.
Old Nov 25, 2008 | 09:34 AM
KySilverado's Avatar
I didn't need one when I installed mine.
Old Nov 25, 2008 | 11:54 AM
budhayes3's Avatar
PT's Slowest Truck
Good to know...I don't have one and plan to do a trutrac eventually when I do my trans...
Old Nov 25, 2008 | 12:14 PM
Wilde Racing's Avatar
How do I change this text
Deffently easier with, but not needed....
Old Nov 25, 2008 | 03:14 PM
Mangled03gmc's Avatar
Baltimore Whore
Mine went in no prob, had to tap the shims a tad, but nothing drastic by any means
John
Old Nov 25, 2008 | 06:59 PM
Dirty Dave's Avatar
Usually you can start the shims by hand when they get 25 to 50 percent in, you should have to tap them.
Old Nov 25, 2008 | 07:00 PM
dirt track racer 81's Avatar
ive done 20-30 rear ends and never had to use one. as long as everything is lined up straight nothing should break
