Developed a Transmission leak without driving
Old May 28, 2006 | 11:47 AM
James B.'s Avatar
Originally Posted by ranwalk
I got the truck running, topped of the transmission fluid and took it for a drive.
No leak detected after driving it
So it's running again? That's good to hear! I hope it runs longer this time, you haven't caught a break with it YET.
Old May 28, 2006 | 12:13 PM
ranwalk's Avatar
Yep,it's running again, lol. At least this time it was down by choice
Old May 28, 2006 | 01:16 PM
BayouSS's Avatar
You probably will not have any further leaks if your truck is driven regular. Fluid will flow from the converter back into the trans pan causing higher levels in the trans case causing fluid to leak pass the inner rear housing o ring that prevents trans fluid from seeping along the output shaft/driveshaft splines. My truck sets up quite awhile sometimes so I just silicone or Jb welded on the little weep hole in the yoke shut. I do know that this hole was put there for a vent when the yoke slips in and out of the trans but I never had trouble from doing this.
Mossyoakglock
Aug 28, 2015 12:49 PM
meadows
13
Aug 25, 2015 08:29 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
1320Chicken
Jul 14, 2015 10:58 PM
Nimoryan
Jul 5, 2015 03:50 PM
