Cracked flexplate vs Trans going out
Old Sep 3, 2013 | 04:29 PM
GMCtrk's Avatar
Default Cracked flexplate vs Trans going out
Nasty loud buzzing/grinding noise coming from underneath the truck, and seems to be from the trans area while driving. Anything more than light throttle input gives the noise which will last about a second or two then go away. Didnt get on it at all for fear of having to be towed again. Seems more like trans to me? Also entertaining the idea a cracked stock flexplate. Motor seemed to be okay but you never know. Thanks.
Old Sep 3, 2013 | 05:44 PM
skeet's Avatar
sounds like flexplate, look through the inspection port with a flashlight and mirror check around the bolts, if no signs of cracks then move to transmission !
Old Oct 1, 2013 | 07:38 PM
GMCtrk's Avatar
Just an update, I pulled all the turbo stuff off from the underside and removed the converter inspection cover. The flexplate appears intact. So the noise could still be the transmission or the torque converter but I'm leaning towards the trans. Noise only happens once everything get well up to temperature. From the dipstick the trans fluid is cherry red, smells normal. Next step I will drop the trans pan and see if there's anything going on in there like metal debris or a clogged filter. Thought I could get away with a stock 4l80e, guess not.
Old Oct 3, 2013 | 11:15 PM
LS1TRUCKGUY's Avatar
do you have a 1 piece or 2 piece drive shaft? my dads did the exact same thing you are describing, and it was the carrier bearing on his 2 piece driveshaft
Old Oct 3, 2013 | 11:31 PM
GMCtrk's Avatar
2 PC shaft. I visually inspected the driveshaft and also checked the u joints. Everything was tight but I'll give a second look to the center section when I get back under it.
03chevytruck
Nov 7, 2016 04:43 PM
pittman
Jan 19, 2016 07:06 AM
Cha_Feel_
Sep 2, 2015 04:29 PM
ALL ULL C
Aug 16, 2015 08:56 PM
1320Chicken
Jul 14, 2015 10:58 PM
