Corvette servo? worth it?
Originally Posted by slammedS10
If everyone where to slam on there brakes and lock them up immediatly your brake pads would not wear as quickly as a nice smooth gradual stop. I hope I didnt confuse you at all.
I dont understand where you read that everyone tranny is screwed up because of a vette servo?? It will actually prolong the life of your tranny by putting more pressure on the bands, thus increasing the life of the the bands. In a stock tranny they set the pressure low so that the tranny has a smooth shift, in order to do this you reduse surface pressure on the servo drum, this also causes the band to wear faster. To put it in simple terms. If everyone where to slam on there brakes and lock them up immediatly your brake pads would not wear as quickly as a nice smooth gradual stop. I hope I didnt confuse you at all.
Originally Posted by inmywhitez
oh and by the way i love my nelson tune! highly reccomended! Only thing i need to fix is 1st to 2nd shift, its not horrible but i like things to be functioning to its peak.
-hey new guy, when i install this servo should i get my tune changed to lower my line pressure?
SERVO RELEASE CHECK VALVE 700R4 4L60E / CORVETTE ETC Item number: 7999945256 ?????needed?http://cgi.ebay.com/ebaymotors/SERVO...99945256QQrdZ1
Originally Posted by $theNEWguy$
see what happened to mine the inside piston will fit on the pin either way and the way the guy that put my piston in was the wrong way.... there for it had to much presure than it was supposed to and it blew the whole bottom off of where the metal ring holds everything in.
Thats was an improper install from a moron, If you know what your doing you cant screw it up. simple install, pull the c-clip out look at how the old one is put together and reverse te procedure.
Let me rephrase my statemnt, Show me a tranny that has failed prematurly to a PROPERLY installed servo. !!!!!! I am a mechanic for a living, trust me, they wont screw uo your tranny, anyone on here with any common sense will backme up!!
I had mine installed by A & A Transmission here in my home town, Rick Allison is a racer that knows his transmissions. If he thought there was anything wrong with the swap, he would have steered me away from it when I suggested one be installed in my transmission. The shifts are very strong, and I like it that way, with the shift kit. Put me down for a yes on the Corvette Servo, great results. Keep in mind you get what you pay for. Kills me to see how many buddies tear up other peoples stuff, lol.
yeah it really sucks having to spend money on something you don't want to... well i got my tranny in today and servo installed to shifts a hell of alot better when it's installed the right way!!!!
