Correct Output shaft?
Old Dec 14, 2010 | 03:46 AM
C-WAY's Avatar
Default Correct Output shaft?
Ok so Im buying this 2wd output shaft for my 06 GMC and converting my 4wd to 2wd with the shaft and the tailhousing. I found this output shaft and want to make sure its the same one, can yall help me out? I posted the exact picture of it and just want to make sure before I go tearing into the tranny
4L60E 18 3/16" Output Shaft.
Old Dec 14, 2010 | 06:58 AM
Vince B's Avatar
Yes the shaft is the correct one. In a 2wd truck there is also a pressed on sleeve with an oring seal inside of it for a vented yoke. You will still have to get this piece or seal the hole in the yoke. Otherwise it will leak. Vince
Old Dec 14, 2010 | 06:30 PM
C-WAY's Avatar
Do you know where to get this sleeve? I just got in my new tailhousing and it has new o-rings and that black seal on the outside of smaller end of the tailhousing, is that what your talking about?
Thanks for the help btw
Old Dec 19, 2010 | 10:48 AM
Vince B's Avatar
Your tail housing will have two seals on it. One for the yoke and one for the main case to tail housing. The one I was talking about is actually pressed on the output shaft that seals the yoke to the shaft. This is needed as I mentioned earlier because most all trucks use a vented yoke. Here is a part number for what you would need to purchase from a dealer. 8654063 Hope this helps. Vince
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Gadgetized
Oct 22, 2015 09:06 AM
JordanH
Oct 3, 2015 03:59 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
