Converter Suggestions
I've been lurking the drive train section for a while trying to figure out what to do about a converter, but to no avail. So I'm hoping a specific thread will help. I have a 1999 Chevy Suburban (OBS) with a Vortec 5700 with a Comp 218/224 @112 cam in it. The trans has a Transgo HD-2 and a big cooler, but it needs a stall. I'm currently running the stock stall in it and needless to say it's sluggish. Once the truck gets over 2300 RPM or so in first it pulls very well. So I need a converter suggestion and some advice as well. Is it true that a converter from an LT-1 Camaro would stall higher in my truck due to the weight? What would be a good number to get considering cam specs and weight? Thanks in advance.
Do you ever tow with it? Yank 3000 TT Series would be a nice match with the cam you have. I have the 2600 on a stock cam and it works great. It will drive very close to stock, untill you put your foot down that is.
The LT Camaro will be the same stall. You need one from a 4.3 blazer. It will be about a 2200-2400 stall. We can build you one and make it HD. I also noticed you are in JV, we are right around the corner from you.
Chris
Chris
We can definitely go that high, but that is a lot for a 5.7 and a heavy Suburban. I think the high stall 12" will be a good match for you. Maybe you could stop by and we can go over your options.
Chris
Chris
