Converter lockup
Old May 14, 2006 | 10:51 PM
Blown02Sierra's Avatar
Default Converter lockup
how much load can the factory 60e converter hold in lockup?
Old May 15, 2006 | 10:57 AM
t t t
Old May 16, 2006 | 10:24 AM
Yank's Avatar
LS1Tech Sponsor
The converter clutch is rated by engine size and use in the orginal application.
the clutch in the Trailblazer unit is rated for use of 325 ft lbs and the 6.0 converter is rated higher about 380 ft lbs on the clutch damper assy.
this clutch lining is a material called carbon ceramic weave that is designed to slip and will not 100% lock up but the damper assy. will bottom out at the designed torque input
Old May 16, 2006 | 11:25 PM
oh... ic. So if i were to get my tc to lock up and then hit WOT, the dampener would bottom out and the clutch will slip/burn up?
Old May 17, 2006 | 07:02 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
No.
Depending on your speed/gear and tune, the converter unlock at partial throttle to prevent engine lugging.
Old May 17, 2006 | 04:36 PM
so it could handle 475 lbs/ft of torque locked up?
Go5.3tt06
25
Sep 4, 2016 10:25 AM
TAPyvehc93
Jan 8, 2016 10:47 AM
jtphelps289
Sep 11, 2015 06:37 PM
06 4.8
Sep 11, 2015 10:36 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
