converter install
can someone tell me the right way to install a converter in a 60e because i dont want to mess up the pump. i have read put som atf fluid in converter put in tranny spin and twist and should here it click 2 time and there should be a 1" of space from lugs on converter to face of bell housing. then i have read to use vise grips to hold it in place while you place it in the truck how do you do this?
I've installed a couple here recently. I didn't hold it in place either time. No problems. Just raise the tranny up slow and check it again right before you bolt it up. Pull it up slow with the bolts and verify clearance in the access hole by spinning the verter. Should be no problem.
it should "click" into place twice. if you feel it click and slide up twice then it should be fully engaging the front pump.
always put a little trans fluid in the converter before you install it. atleast 1/2 a quart, a full quart is better if you can get that much in it. lots of moving parts inside the converter need fluid for lubrication. CHIP
sounds like youre on the right path
just measure the bellhousing to pads
and make sure theres at least an inch there
this should be pretty easy with your truck sitting as high as it does
the whole vice grip thing just makes sure the TC doesnt come forward
I didnt bother with it
do like Ky said and double check it right before
you mount it to the block
is this the stock verter?
yeah it be the stock one it went right together no problem but does anyone have a good way to put my t-case in its pain tryed just man handling it but get it up there and i couldn't get it to line up and could only handle it so long.
Took like 5 min. this time. You may also need to put the trans in neutral and spin the shaft to get the splines to line up. It can be a PITA.
LCHEE
Oct 24, 2020 04:10 PM
KyleW707
Jul 29, 2015 08:17 AM
GMCtrk
Jul 17, 2015 06:39 PM
