coilovers
Old Jan 2, 2015 | 02:02 AM
  #21
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Originally Posted by Blown06
I gotta agree with most on here, you'd be going backwards with a ridetech shock and a streetable spring for drag racing. If you have a street truck though go for it. Also, the arms will only save you about 15 lbs total. So $1100 for 15 lbs isn't a real good return.
I'll have about $4000 in my new front setup but it's gonna loose nearly 150 lbs (probably more than that). Ridetech arms, custom belltech spindle, madman brake kit and custom valved afco coil overs.
My opinion, the set up I used to run worked awesome. Drop springs and an adjustable qa1. I was able to cut 1.5 60's (in street trim) or 1.3 60's (in race trim) with a 4/6 drop. It's affordable for most, cuts great 60's, and can be tightened back up to have a comfortable street ride.
yeah this is what I'm looking for i mostly drive the truck on the street but i want it to perform on the track i really don't wanta 4/6 mine but if it comes to that ill do it
what shocks were you running and what was the part numbers if you can remember
Old Jan 3, 2015 | 12:53 AM
  #22
Blown06's Avatar
8 Second Truck Club
I dont remember without digging through a ton of paper work. Basically, I did as stated above, set the truck at ride height, figure out what the shock length needs to be at ride height, figure out how much stroke you want (for comp and reb) and go from there. QA1 has specs for all their shocks on the line.
Old Jan 3, 2015 | 08:21 AM
  #23
dirt track racer 81's Avatar
I cut the top out shock mount and I'm running a $110 7" stroke heim end gas shock.. I just made mounts for it.. Set it for 2" compression and 5" extension. Im going to see how the these light springs do for weight transfer, if they don't do what I want I'm going to make the jdm lighting springs fit and see how they do.
Old Jan 3, 2015 | 12:09 PM
  #24
i bought a set of single adjustable QA1s last night there 15.5 extended 10.25 compressed there actually for a 97-03 F-150
and the rear shock brackets to relocate my shocks out back I've just gotta figure out what length i need for out back
Old Jan 4, 2015 | 09:57 AM
  #25
brandon6.0's Avatar
Like stated. Weld all mounts in set ride height and measure.
Old Jan 4, 2015 | 06:20 PM
  #26
PaulyC's Avatar
Originally Posted by 02_Orange_D1SC
were in mass you from id love to check out cooks old truck haven't seen that thing in awhile plus go for a ride and see how much better the truck rides with the coil overs
haha im from quincy actually. the truck is currently off the road because i dont have time to drive it anymore between working two jobs and all my other hobbies. plus i want to redo the mounts for the coils so it needs to have some work done before i can really drive it again.
Old Jan 4, 2015 | 08:27 PM
  #27
Tig's Avatar
Tig
Pauly,
You own Cooks old truck?
Did you make any changes to it?
Old Jan 5, 2015 | 03:46 PM
  #28
PaulyC's Avatar
yea i do. the only real change is the front is on coilovers, the rear is still bagged. come spring itll probably (hopefully) be on coils on all four corners.
Old Jan 10, 2015 | 07:15 PM
  #29
Tig's Avatar
Tig
Nice, that's going to handle like its on rails.
What coil-overs did you go with?
Old Jan 10, 2015 | 10:22 PM
  #30
SumtinCoo's Avatar
This is what I need. I can't get my truck to transfer weight for anything. Did you also remove your sway bar with the old set up or did you keep it? I'm sure the new set up won't have it. I'm really thinking about taking mine off and relocating the other shock to the back as well in the rear. Truck is also at 4/6 and I already have competition engineering drag shocks in the rear
