coilovers
Old Jan 1, 2015 | 01:17 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Default coilovers
I'm looking at doing a set of coil overs no clue what i need my truck is lowered
2-4 right now id like to stay at that height
I'm thinking 900lbs springs should work for me
im leaning towards the ridetechs
Old Jan 1, 2015 | 01:35 PM
TheBeeblebrox's Avatar
How is your truck lowered currently, in the front?
900# sounds about right.
Old Jan 1, 2015 | 01:42 PM
drop springs up front I'm looking at maybe ditching the stock boat anchor control arms and doing the strong arms
Old Jan 1, 2015 | 01:58 PM
It looks like you would be able to get away with the 5.2" stroke shocks from RT (with a 10" spring), If my math is correct, at only 2" drop it would put those shocks in the sweet spot of there travel range. Of course I would still recommend measuring the see where you are at now just to make sure, I think you would be about 14" from LCA shock mount to upper shock mount.
With RT's Strong arms I'm not sure if they change the mounting position in relation to stock, but I imagine it would be fairly close (I think they have 3 mounting points too).
Old Jan 1, 2015 | 04:06 PM
PaulyC's Avatar
the ridetechs drop the mounting point around an inch i believe, id have to go out and measure mine. 900lb springs will be fine for a rcsb. the best way to measure for shocks would be to get the new arms and mount them up, set your ride height and measure between the two points.
Old Jan 1, 2015 | 04:21 PM
so i have to measure from the bottom shock mount to the upper one?
can the truck be on the lift or does it need to be on the ground?
Old Jan 1, 2015 | 04:25 PM
Yes, from the lower shock mount to the upper shock mount, truck needs to be at ride hight, so on the ground/drive on lift/ramps/blocks whatever works as long as the suspension is loaded.
Old Jan 1, 2015 | 04:33 PM
PaulyC's Avatar
i had my truck on jack stands and had the tire mounted with no suspension. jacked up the lower arm until the tire was where i wanted it and measured that distance. to find a shock of the right size you take that first measurement and find a shock that is close to that at 50% compression for street driving.
Old Jan 1, 2015 | 04:45 PM
were in mass you from id love to check out cooks old truck haven't seen that thing in awhile plus go for a ride and see how much better the truck rides with the coil overs
Old Jan 1, 2015 | 04:56 PM
gamble686's Avatar
Hmmmm if I am running a stock front ride height on a ecsb what do you think you would recommend? I would guess a little more stroke and maybe 1100lbs?
