clunking when going from reverse to drive
Old Mar 21, 2007 | 07:47 PM
Tootall's Avatar
. . . . i wish i had someone who could put it in drive and reverse while i was under there...
ahahah yeah you can, get a shop light, (put it under the rear diff) or a flash light, hang yourself upside down, on the drivers seat, and use your foot to hit the shifter, (be sure that the parking break is on). Yes it works, lean over, push it over, watch it move.
. . . .but is that hanger thingy in the middle suposed to have any play? when i push up/down or side/side i can get that to move.
yeah that's supposed to move, about an inch and a little more if you're trying to shove it. Any more, and it'd be like you're missing a rear tire, or as if it's getting ready to fall off.
Old Mar 21, 2007 | 07:50 PM
TXsilverado's Avatar
so i have 2 yokes? one at the transmission and one in the middle just behind the hanger thingy? which one is it that i need to grease?
Old Mar 21, 2007 | 08:04 PM
Tootall's Avatar
you have one on the trans side . . . kinda have one in the middle, there's some other terminology for it.
the one in the middle has the fitting, past the carrier bearing, the one that moves up and down, their splines that you're greasing. If you've never done it before, it'll take a while. Pump it at least 10 times, you'll see a little bushing that's metal on one end, and has a rubber bushing on the inner side. It's going to flex back and forth as it fills with grease. It'll shoot out between the two yokes when it's "full." You can't over grease it, the excess comes out
Old Mar 21, 2007 | 08:14 PM
so i dont want to grease the shaft coming from the transmission then. im not sure if greasing the yoke behind the carrier bearing is guna do the trick. i had it greased only a few months ago.
Old Mar 21, 2007 | 08:26 PM
Tootall's Avatar
Correct, unless you have greaseable u joints,
true, I was trying to make sure that you had been doing that, if you hadn't in 60K hard miles, then that would have been something.
I'd start looking at the rear for the clunking.
Old Mar 21, 2007 | 08:36 PM
damn then the transmission will be next...then i should be golden but still with a truck note and stock cam
Old Mar 21, 2007 | 09:47 PM
Wheatley's Avatar
Truck Sponsor
Damn Stuart.That sucks man.Although you do drive the hell out of that thing.LOL
ARC
57
Feb 21, 2022 10:54 AM
chvy=power
Sep 8, 2015 11:06 AM
USMCvet0311
Sep 4, 2015 09:43 PM
Ketis
Jul 23, 2015 12:37 PM
lo&sloSierra
Jul 19, 2015 04:21 PM
