Close Ratio Gearing for a 4L60E
Old Dec 17, 2007 | 12:13 PM
Savage Sierra's Avatar
Question Close Ratio Gearing for a 4L60E
Does anyone know how installing close ratio gears in a 4L60E could effect drag strip times? I'm thinking that it would have to help because there would be less rpm drop between shifts and the power band would be flatter.
What do you guys think?
Old Dec 17, 2007 | 08:16 PM
Dirty Dave's Avatar
I have been thinking about putting the rear planet out of a th350 in for a while. It would raise the first gear and close the gap between first and second. The rear planet would be stronger that way too. You would have to reprogram the ecm so it would not set ratio codes.
Old Dec 17, 2007 | 09:11 PM
03chevy5.3rcsb's Avatar
doesn't a higher stall converter do that?
Old Dec 17, 2007 | 09:27 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
As far as I know there is no different gearing presently available for the 60e and while the th350 gear looks similar the design is such it will not swap in ,
Old Dec 17, 2007 | 09:50 PM
Dirty Dave's Avatar
The 4l60 carrier fits in a th350 why won't a 350 fit in a 60?
What other options would I have without messing up the ECM controls?
Old Dec 17, 2007 | 10:04 PM
built408's Avatar
just get a higher stall converter. will have less rpm drop on gear changes.
Old Dec 17, 2007 | 10:28 PM
I thought I was missing something, but my thoughts exactly
Old Dec 17, 2007 | 10:40 PM
Originally Posted by Dirty Dave
The 4l60 carrier fits in a th350 why won't a 350 fit in a 60? You just use the rear planet and ring gear of wichever gear ratio you prefer.
Similar but try it trust me I looked at it hard just wont work
Old Dec 17, 2007 | 11:14 PM
Dirty Dave's Avatar
Well crap I think you're right. The 4l60 carrier has an extra set of splines.
