Circle track slicks?
Old Oct 23, 2006 | 01:58 PM
kbracing96's Avatar
Isn't there in issue with fitting 15" wheels on the back of these trucks, I may be wrong, but I though I saw something about this?
Old Oct 23, 2006 | 02:00 PM
nightrunner's Avatar
Mr. Obvious
i think its brake clearance
Old Oct 23, 2006 | 02:01 PM
dirt track racer 81's Avatar
grind the calipers down..been done before
Old Oct 23, 2006 | 02:20 PM
Mangled03gmc's Avatar
Baltimore Whore
YAh we used them on our car after picking them up for 25 apeice, and they were the same size.. You have to smoke em good but they do get sticky and hook fairly good, for that cheap it is worth the try..
Old Oct 23, 2006 | 04:20 PM
TurboGibbs's Avatar
I did several loooooong burnouts on mine and I couldn't tell a difference in the check holes after I had abused them. Mine were asphalt tires so they may have been a harder compound. The Mcrearys that I had were much softer and didn't last any time. I found that the Mcrearys would hook better with around 20 psi in them rather than less. The sidewall is so stiff in them that when you let it down too low the tire would cup up in the center and when I would spin them it would leave two thin black markes off the outer edges of the tire and none in the center.
Old Oct 23, 2006 | 07:26 PM
there are several different compounds and different sidewall stiffness...the tires i got on the softer side and have soft sidewall..they will wrinkle..on my dirt track car i run anywhere from 7 psi to 14..depending on front and back-left and right..i will try 8 psi first
Old Sep 7, 2011 | 01:08 PM
tylerherrin's Avatar
Registered User
Default need tires
still have the hoosier 27/10/15's
Old Sep 7, 2011 | 01:28 PM
silver-mod-o's Avatar
Hunt&Fisherator
please check the dates on the threads you bump... this one is pushing 5yrs old
madmann26
Apr 29, 2020 09:17 AM
AdaMax
May 16, 2016 11:35 PM
Vortec350ss
Jan 12, 2016 10:36 PM
Wolftrk99
Oct 2, 2015 08:17 AM
sTNT971
Sep 26, 2015 06:27 AM
