Circle D - Multi Disk
Old May 24, 2009 | 10:13 AM
  #41
Circle-D's Avatar
Former Vendor
Originally Posted by moregrip
I couldn't remember if my new FP had provisions for 6 bolts or not, but it looks like it does, I may have to give your converter a try when I return from deployment
Sounds like a plan, we will be here when you need us. Thanks for the service by the way, I appreciate it. We do offer Military discounts.
Chris
Old May 24, 2009 | 01:34 PM
  #42
fossil's Avatar
11 Second Club
Chris, what hp or tq numbers to use a 6 bolt cover?
Old May 24, 2009 | 08:25 PM
  #43
TURBHOE's Avatar
so the ls1 4l80e hybrid thing takes away the need for the spacer? does it also have 6 bolts? i'm looking at doing a 4l80e swap in my AWD Tahoe. i tow and want 800hp for weekend high boost use. 10psi daily driving.
Old May 24, 2009 | 10:41 PM
  #44
silver-mod-o's Avatar
Hunt&Fisherator
The LS1 cover does away with the spacer but has 3 bolts. Bolts to stock 4.8/5.3/LS1 flexplate
Old May 24, 2009 | 11:21 PM
  #45
GMCtrk's Avatar
yep, that's cool as hell. Dont even have to bother switching the flexplate out
Old May 25, 2009 | 09:01 AM
  #46
TURBHOE's Avatar
how much power do you all think a 3 bolt can hold before they shear?? and can you get that one with the triple disk.
on the site it says 100 square inches of clutch area. i always wondered, what does that compare to like a normal stick shift clutch.?
Old May 25, 2009 | 06:31 PM
  #47
Circle-D's Avatar
Former Vendor
The multi disk billet front we make has an extremely strong mounting pad. I would feel safe saying it would hold 2000HP, the mounting pad that is. The problem is the flex plates break. So by distributing the load better, it helps to eliminate breaking flex-plates. So the 6 lug option with a SFI approved flex-plate is the strongest setup. The LS1/4L80 Hybrid converter lets you use the stock flex-plate because it has the stock LS1 bolt pattern and correct pilot length to engage in the crank. I am not sure what HP levels are needed for a 6 lug flex-plate or a SFI one. I have seen a lot of them crack in near stock applications and some live in 6-700 HP. I think you are required to run a SFI 29.1 at 9.99 or quicker, if that helps any.
Chris
Old May 25, 2009 | 06:49 PM
  #48
2005 Silverado's Avatar
SPAM HUNTER
What makes the 80e verters so much more expensive, not complaining just wondering y a 60e verter can be found for alot lot less.
Dustin
Old May 25, 2009 | 07:29 PM
  #49
MikeGyver's Avatar
I'm interested in a lower stall speed. How low can you go?
Old May 26, 2009 | 06:56 PM
  #50
Luke03's Avatar
Hey Chris... say if i ever get a 6.0 and want to upgrade to a multi-disk is there any way i could trade in the 4000 i have and just get it upgraded?
