caster/camber after 4/7 drop on NNBS HELP!
Old Dec 1, 2009 | 02:26 PM
illMATTic's Avatar
Default caster/camber after 4/7 drop on NNBS HELP!
I installed a Belltech 4/7 drop a couple weeks ago. I used the spindles and struts up front. I also installed their 2* UCA bushings. The bushings were a SOB by the way.
I took it to get alligned and the shop said they maxed out the UCA adjustment but could not get it within spec. I called Belltech and of coarse they told me it should adjust out and would not offer any other help.
Have any of you had this problem?
Thanks, Matt
Old Dec 1, 2009 | 02:46 PM
08Chevy's Avatar
I have ground force spindles and belltech struts and my aligned up perfect without bushings.
My friend has a belltech kit and just needs to order the camber kit to fix his problem. Have you tried a different place?
Old Dec 1, 2009 | 03:02 PM
illMATTic's Avatar
I havnt yet. I may take it to another one of their locations for a second opinion since it wouldnt cost anything.
I looked at the UCA and it is out all the way so the alignment shop may be correct. Belltech told me that adding the struts adds 2* and that by adding the 2* bushings it should be a wash. He said their spindle has no effect on camber. He has to be wrong.
I wonder if some belltech spindles could be bad.
Old Dec 1, 2009 | 03:37 PM
08Chevy's Avatar
Yes it effects the camber but not sure why they didn't tell you to get a camber kit to correct this problem.
Like I said, my friend has the same drop and all he needs is a camber kit to fix the problem and then its done. But the shop is wrong saying that even with the bushing that it will not fix the problem unless they fucked up something else while doing the alignment.
Old Dec 1, 2009 | 05:02 PM
illMATTic's Avatar
I have the camber kit istalled already. I did it when I did the drop. The spec sheet from National Tire and Battery states the camber is at -6*. This is after they tried to align it.
Old Dec 1, 2009 | 05:17 PM
454navyss's Avatar
you didnt put the bushings in backwards did you? the hole should be closer to the outside of the bushing. if you did everything correctly it should be pretty close to being right
Old Dec 2, 2009 | 08:06 AM
illMATTic's Avatar
I did make sure to install the hole away from the balljoint.
Old Dec 2, 2009 | 08:16 AM
08Chevy's Avatar
I just don't see how you're off that much with everything installed how you're saying its installed. Maybe get back under the truck and just double check everything yourself. Thats all I can think of right now.
Old Dec 2, 2009 | 02:24 PM
454navyss's Avatar
the hole is supposed to be towards the ball joint if im not mistaken, at least thats how it would be on my truck
natejk
Nov 15, 2016 08:05 AM
GMCtrk
Jan 27, 2016 06:47 PM
chvy=power
Oct 20, 2015 09:08 AM
screaminian47
Sep 7, 2015 08:20 PM
xerox17
Sep 5, 2015 01:23 PM
