Can't remove bellhousing on 4l60E
Old Feb 22, 2011 | 04:55 PM
Ieatpeople's Avatar
Default Can't remove bellhousing on 4l60E
i have the trans removed from my truck (2010 4.8l rclb 4wd), because i am installing a performabuilt lvl 2. however, i have run into a small problem. what freakin' socket/bit is this?!
it looks like a big philips bit, but i can't find anything even close.
this is what gm used to hold the bellhousing to the trans.
Old Feb 22, 2011 | 06:37 PM
Vince B's Avatar
That is a new bolt being used by GM. I actually ran into the same problem and had to buy one that is made by kentmore. I'm not sure if I have it here at the house or if its in my other box at the shop. Let me look to see if I can get you a part number for that tool. Vince
Old Feb 23, 2011 | 10:39 AM
Ieatpeople's Avatar
Vince, if you could get me that number that would be fantastic! I really need to get this trans shipped!!
Old Feb 23, 2011 | 11:17 AM
Robert91RS's Avatar
Its called a "mortorq spiral fastener" Kent-Moore # DT-49037
http://www.handsontools.com/Kent-Moo..._p_69440.html#
Snap-On Part # PFMTS4E
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Feb 23, 2011 | 11:19 AM
Robert91RS's Avatar
Incase anyone cares to know more useless info lol.....
A little background on this new type of fastener:
Mortorq®
The Mortorq Spiral Drive recess developed by Phillips, is much shallower than other standard recesses on the market, and can be put into a much shallower head without affecting the strength of the screw. This assembly allows for a shallower counterbore, reducing material thickness without compromising the joint strength, because it does not affect the material thickness below the counterbore. A Mortorq recess uses full wing contact with driver bit in both drive and removal directions.
Advantages and Disadvantages of Mortorq
Aerospace designers have had to compromise on fastener performance. Previously, shallow head styles had poor torque transfer and damaged easily while robust drives required thicker material and added weight. The unique shape provides full contact of the driver over the entire recess wing resulting in extremely high torque capability without the risk of damage. Depth of the recess in the fastener head is minimized resulting in true high performance in 100 degree flush head and shear head applications. The open recess concept allows driver to recess misalignment and compensates for paint build-up without degrading torque performance. Workers can easily install and remove panel and structure fasteners at odd angles without high muscle stress or fear of damage to surrounding surfaces. Larger driver cross-sections and curved surfaces provide extended tool life and resistance to tensile fatigue fracture when used with high load pulse tools.
Old Feb 23, 2011 | 02:01 PM
Ieatpeople's Avatar
thanks alot guys , i have to call my snap-on guy to see if he has one!
Old Feb 28, 2011 | 06:16 AM
Vince B's Avatar
Looks like I was a little slow here! To be honest I forgot that I took the pictures and also to update the thread. Here is what I got. Vince
Old Feb 28, 2011 | 10:24 AM
budhayes3's Avatar
PT's Slowest Truck
Hmm, I guess that the special torx bit (T-55 Plus) wasn't good enough so they had to go and change it up again...great, another tool that I just "have to have"
Wolftrk99
Dec 3, 2015 08:12 PM
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
Wolftrk99
Oct 2, 2015 08:17 AM
