Can a trans cooler be too big???
Old 12-04-2009, 04:23 PM
imallstressed's Avatar
Default Can a trans cooler be too big???
My 03 Sierra Denali has a small trans cooler that the previous owner added. My friend just gave me a Summit sum-g4969. It's an aluminum tube and fin that is 21x10.5 and 1.5 inch thick. Is there a disadvantage to this cooler? I do have a 3200 stall Circle D and other boltons along with a tune on my truck.
Old 12-04-2009, 04:33 PM
chevrolet all the way's Avatar
no its wont be too big. you can only get to a certain temp before it doesnt help anymore but it wont be too cold or anything like that
Old 12-04-2009, 04:44 PM
1Bear's Avatar
Due to it being a tube & fin design, I would venture to guess a cooler of those dimensions is probably in the 28K GVW range. There are so many people using the TruCool Max 40K GVW without problems, I doubt that you will have any issues.
Old 12-04-2009, 04:50 PM
skeet's Avatar
i run 2 coolers lol 140 tops on the tranny no issues
Old 12-04-2009, 04:57 PM
ZR1 DREAMING's Avatar
You will not experience any negative issues/effects with a large trans cooler.
Old 12-04-2009, 05:05 PM
Thanks for the help guys. I am installing a new trans next week. I was going to put this in at the same time if it was ok, and it looks like I'm going to be.
Old 12-04-2009, 08:24 PM
14psisupra's Avatar
if the temp is in the 50's or below it might take a bit of driving before your tc will lock up.
Old 12-04-2009, 10:15 PM
WJ MARK's Avatar
bigger the better when you have a stall IMO.
Old 12-25-2009, 10:21 PM
cwalker2006's Avatar
i have a trucool max 40k gvw and when its 40 and below and i leave work which is 15 miles away. i get like 4 miles from town before it finally locks. kinda annoying sometimes.
Old 12-25-2009, 10:28 PM
1Bear's Avatar
I don't know whether you done it or not, but you may be knock a little efficiency off by painting the cooler. It may be just enough so as to let a little more heat into the trans without resorting to adding a bypass.
Quick Reply: Can a trans cooler be too big???
