Can 4l80e guts fit 4l60e case
Old Nov 29, 2008 | 07:53 PM
gmc03's Avatar
Default Can 4l80e guts fit 4l60e case
I am building 408ci 6.0 and need a trans to hold the estimated 450rwhp. My truck has a 4l60e i heard tougher 4l80e guts will fit???? I also am converting it to eldbrocks carb setup and was wondering what kinda headache i was looking at as far as reprograming pcm with the carb setup. And where to get throttle cable setup.
Thanks for your input
viciousknid's Avatar
Where's the Beef?
No. completely different transmissions.
Old Nov 29, 2008 | 08:03 PM
RandomHero's Avatar
That's true, but I've heard of such a thing. If I remember correctly there was a company that was able to fit 4l80e parts into a 4l60e. Short answer no though.
Old Nov 29, 2008 | 08:23 PM
and you will not have a pcm with the carb setup you might wanna use the search button and check out stuff a little more it will be your best friend.
Old Nov 29, 2008 | 08:28 PM
Where's the Beef?
Do a search for carb or variations of it. There was someone a few months back that put a carb'd 6.0 in his 70's or 80's? model truck.
Old Nov 29, 2008 | 08:34 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Older 4L60/700r4 would work. Need TV cable & vac lines, and adapter parts to make older trans work. I've heard of it being done on another board. Not sure about this one though.
Old Nov 29, 2008 | 08:40 PM
Where's the Beef?
Here's the thread you want.
https://www.performancetrucks.net/fo...ight=carb+swap
Old Nov 30, 2008 | 12:50 AM
James B.'s Avatar
It is not possible. The 4L60-E and 4L80-E have nothing in common mechanically. The only answer is "no".
Old Nov 30, 2008 | 01:00 AM
RandomHero's Avatar
give me a second and I'll find it....
EDIT-I don't want to claim something exists, but I could swear I read something to that extent.
Old Nov 30, 2008 | 01:08 AM
RandomHero's Avatar
Ah nevermind. It was an article about retrofitting th400 parts into a 4l80e. My appologies
