Caltrac bushing???
Old Dec 6, 2010 | 08:13 AM
lownslo's Avatar
Default Caltrac bushing???
I have a set of caltracs that are missing the bushing for the front spring eyelet.Can i use the stock bushing or should i try to pick up a different bushing or what? I see some people just shave the stock bushing down, but I want to make sure this works. Also do you have to purchase this bushing from caltrac or can ya buy it local?
Old Dec 6, 2010 | 09:12 AM
TXsilverado's Avatar
its a calvert part, but im sure a machine shop can make it for you if you have the deminsions. i would want the bushing in there. it's the main pivot point for the setup and i wouldnt want it squishing around in there. see if you can find a polyurithane bushing for it at the least.
Old Dec 6, 2010 | 09:26 AM
lownslo's Avatar
im waiting on calvert to open and see how much they want for the bushings! I hate to spend a fortune to have someone turn a set and not know what size either!
Old Dec 8, 2010 | 09:47 PM
sleepersilverado's Avatar
I think i have a spare set of the aluminum press in pieces but not the steel inserts. I will have to look at the shop next time i go there. See what caltracs says though their customer service is pretty good. Also if you want to get a hold of me pm me because i rarely get on this site.
Old Dec 8, 2010 | 10:47 PM
silver-mod-o's Avatar
Hunt&Fisherator
Only use the calvert parts IMO... Under those kinds of pressures I wouldn't even mess with poly.
Old Dec 8, 2010 | 11:07 PM
LS1TRUCKGUY's Avatar
dezert1500 used some poly bushings with good success i believe... fwiw, i chose to run the aluminum bushings...
Old Dec 9, 2010 | 12:42 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Less deflection is better. Suspension geometry is important when trying to net a good 60 ft. Get the aluminum bushings, they aren't too pricey.
vmaxpro
Sep 21, 2015 06:46 PM
pewter00
Sep 13, 2015 11:14 AM
02gmc5.3
Sep 7, 2015 08:11 PM
xerox17
Sep 5, 2015 01:23 PM
