C-Notch/Suspension Pics
Old Jan 9, 2006 | 03:04 PM
  #21
Deckhand's Avatar
Originally Posted by Blaze5509
That looks like a nice set up. Should bite pretty good with those caltracs on there!
Just curious what size drop are you running?
Its a 2/4, I will be going to a 3/5 eventually. I mainly did it for ride quality so I wouldnt bottom out on bumps.
Old Jan 10, 2006 | 03:28 PM
  #22
LS1TRUCKGUY's Avatar
Looks Nice, The Only Problem I Had With My C Notches, Was That The Frame Flexed At The Notch And Warped My Bed Ever So Slightly, But They Were Only Bolted In. Then I Went And Had Them Welded And Boxed In. Super Stiff Now.
Old Jan 10, 2006 | 09:26 PM
  #23
negativeswitches's Avatar
job well done look slike nice weather to work outside
Old Jan 11, 2006 | 11:57 AM
  #24
Just Curious If You Had Clearance Problems Between The Sway Bar And The Diff Cover? Also, Which Sway Bar Is That? Hotchkis?
Old Apr 25, 2008 | 11:35 AM
  #25
fastnblu's Avatar
Originally Posted by Deckhand
Thanks, yea I did the welding. With all the weight off the truck... man you can do some good burnouts!
Vids? Where's the nasty burnouts?
Old Apr 25, 2008 | 11:46 AM
  #26
fastnblu's Avatar
Originally Posted by Sport Side
Nice setup.
+1.
Originally Posted by BlackLM7
Wow, I don't know the proper way to C-notch a truck but that looks VERY impressive and professional.
Yes, it does.
The caltracs I have had for a while, they ran me about $380 if I remember correctly through a group purchase a while back. and now I have full adjustability. So far they seem to be working well, and the truck handles nicely with the addition of the sway bar.
From where. I thought only sold thru Calvert?
I just realized how old this thread is.
What caused lack of full adj( before brkt mod, what was limiting adj.) ?
Originally Posted by 1Bad454
I once heard that you shouldn't weld on the factory frame because it will cause it to weaken? At the time the reference was on an OBS frame.
Same here. I thought I heard that on the '99-up especially?
Old Apr 25, 2008 | 12:49 PM
  #27
dlt76028's Avatar
where did you get the c notch? im looking to buy a bolt on one cheapest i can fine. i also heard there is a difference between 99-00 and 01+?
Old Apr 25, 2008 | 01:03 PM
  #28
leochevy2001's Avatar
looks like a djm notch.
you can get those from a lot of places.
i really like the mcgaughy's notch.
i've seen the djm notch up close and it looked cheap.
the mcgaughy's notch looked a lot stronger.
i've haven't seen a belltech notch in person but from the pics i've seen on the i-net they look strong too.
yes, the 99-00 and 01+ notches are different.
i found out the hardway when i bought a used notch for my '01 and the notch came off a '00.
so make sure when you are buying one that you look at the years that it is made for.
Old Apr 25, 2008 | 05:43 PM
  #29
KevinF56's Avatar
wow this thread is over 2 years old...
Old Apr 25, 2008 | 05:49 PM
  #30
bluecajun5.3's Avatar
11 Second Truck Club
https://www.performancetrucks.net/fo...=416687&page=1
and this was why it was brought back
