bumpstops and stock
Old Apr 21, 2008 | 08:50 PM
20tahoe03's Avatar
Registered User
Default bumpstops and stock
my truck is an 03 tahoe 4wd and the front end sits in the bump stops. is this normal it dosent look low or funny in any way do the torsion bars lose their tension after time maybe?
Old Apr 21, 2008 | 08:53 PM
NoChrome's Avatar
yes they do wear, but it shouldnt be resting on the bump stops. I would try to adjust them before I did any thing drastic, if your not the first owner they be fine and some body wanted a lower stance.
Old Apr 21, 2008 | 08:58 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Welcome to the Forum!
Actually they SHOULD be just kissing the stops (at least according to 2 alignment guys I know?). The bump stops are part of the suspension on the 4x4 torsion suspension trucks.
Old Apr 21, 2008 | 08:59 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by trever1t
Actually they SHOULD be just kissing the stops. The bump stops are part of the suspension on the 4x4 torsion suspension trucks.
x2....mine was resting on the bumpstops from the factory when I picked her up with 8 miles on the clock.
Old Apr 21, 2008 | 09:01 PM
20tahoe03's Avatar
Registered User
well i guess that anwsers it thanks guys
Old Apr 21, 2008 | 09:04 PM
NoChrome's Avatar
Seriously? my av had a 1/2in gap at least
Old Apr 21, 2008 | 09:07 PM
20tahoe03's Avatar
Registered User
does anyone know what the front ride height measurement is? then i can check that and go from there
trever1t's Avatar
There is an allowable variation...
Old Apr 21, 2008 | 09:08 PM
NoChrome's Avatar
If the ride isnt rough and there is no funny tire wear I wouldnt worry about it.
Old Apr 21, 2008 | 09:15 PM
20tahoe03's Avatar
Registered User
it dosent ride very tight, very loose where can i find poly front end bushings and upgraded steering componets?
