Bullet Proof 4L60E...?
Old Jul 26, 2010 | 09:52 PM
  #31
Pontiac Derek's Avatar
Also fwiw PATC has 6 pinion billit close ratio gear sets for the 60 if your trying to build the ultimate 60.
from what I've learned you can either use a fully built 60E or an 80 with a shift kit only the 80 will last wayyy longer and take more power, it's just doing the math to see what's cheaper built 60? Or 80 swap?
Old Oct 12, 2011 | 11:01 PM
  #32
zittman's Avatar
Where does one find the Extra Wide Heavy Duty double caged 29 element sprag for the 4L65E??
Old Oct 13, 2011 | 05:03 AM
  #33
Vince B's Avatar
That sprag is a proprietary part for GM and GM reman facilities. You will not be able to get it unless you purchase a whole sprag assembly from GM and they are pricey. Last I checked they are like $200. You need to order one using a 2010 vin that would have a V8 or 6.0L in it. I know some the 09 TBSS used these and some of the later trucks if it helps. Vince
Old Oct 13, 2011 | 05:18 AM
  #34
wkdivr's Avatar
Originally Posted by 00_Hotrod
About a month ago I started Managing a transmission shop and now i want to build me a stout 4L60e trans and a 2500 stall.. I can build it myself but i dont know what some of the best parts are, Anyone know what some of the best parts are that can be put in one of these to make it pretty stout..? sun shells, drums clutchs ect.. and where i can get them..?
How do you manage a trans shop, and don't know where or how to get good parts?
Old Oct 13, 2011 | 06:17 PM
  #35
zittman's Avatar
Would you have a part number?? Is there anything else out there that is close to it? I found a dual cage 29 element sprag that is suppose to be used in high performance applications, don't know how good it is though. Thanks
Old Oct 13, 2011 | 06:39 PM
  #36
TIM Z's Avatar
11 sec. Truck Mod
Old Oct 14, 2011 | 06:33 AM
  #37
Vince B's Avatar
I'll have to look and see if I still have it. Its been a while! In most cases I use the Borg Warner dual cage sprag and it works just fine. I'm pretty sure that is what you saw. If you would like to shoot me a pm with a link to what you saw I can confirm this for you. Vince
Chavette
Oct 28, 2015 07:33 PM
Velocity1
Sep 22, 2015 01:32 PM
Rockrz
Sep 13, 2015 12:22 AM
lxcoupe
Sep 2, 2015 12:58 AM
