Building parts list for 4l80e swap. Help with Torque Converter please.
Old May 23, 2016 | 06:18 PM
tgui's Avatar
Originally Posted by willhorne22
Ok, so depending on my budget I may just use the factory one as long as its the B82.
Do yall know if the blackbeartune - AutoCal and EFILive V2 Email Tuning would let me swap the 4l80e? or they could do that for me?
Or is the hp tuner the best bet?
B82 I think came behind the 4.3 80e combo.
Either tuning software is ok.
If you plan to tune more in the future, getting a tuning setup is a bit $$ up front but allows you to tune all you want for future parts.
Old May 26, 2016 | 09:53 PM
willhorne22's Avatar
If i got a really good deal on a PI Triple Clutch 2600-2800. Would that be a good choice for me, Over a stock one?
Old May 26, 2016 | 11:02 PM
TGUI, Did you buy this transmission holding fixture?
Transmission Holding Fixture w Base T 0156 B | eBay
You just had to grind it down on one side to make it work?
Old May 27, 2016 | 06:53 AM
tgui's Avatar
I don't have one. I drilled a hole in my table top for the shaft to fit in. Then I man handled the thing into various positions.
Old May 27, 2016 | 06:54 AM
tgui's Avatar
I don't know if a triple clutch is good for a daily driver. Someone else will chime in though.
Old May 27, 2016 | 07:41 AM
Oh sorry that was Blown3qtr's rebuild thread with mount.
Old May 27, 2016 | 07:43 AM
tgui's Avatar
Yeah, thanks for rubbing it in! ***.
Someday I'll do that.
Old May 27, 2016 | 12:23 PM
Wolftrk99's Avatar
I bought a trans fixture similar to that and just stuck the shaft in an engine stand with a few pieces of exhaust pipe to make up the differemce it worked quite well....hell still does, lol
Old May 27, 2016 | 02:39 PM
James B.'s Avatar
I agree with those who suggest lower stall RPM. A high-stall converter would be miserable on the trails; it won't crawl and will overheat. You're geared low enough for a stock 13" converter. Multi-disc lockup clutches are relevant to high power-handling during wide-open-throttle lock-up, also not needed for this.
Old May 27, 2016 | 03:25 PM
Wolftrk99's Avatar
Which is part of the reason i went with the converter i did, it is basically a reworked trailblazer 4l60 converter, with a slightly higher stall, my truck will crawl, even with a 3000 stall, reverse takes a bit more rpm to get moving, but rarely do you use reverse anyway....
