Broken 80e!
Old Jul 17, 2011 | 07:13 PM
  #101
smokeshow's Avatar
Mod with training wheels
So, putting all this together gets me to this theory...
-snap ring is put in the wrong spot
-snap ring misplacement allows it to rotate in its groove, causing the clicking noise
-wrong ring allows the intermediate drum to move around (from what I gather)
-movement cracks o-ring on intermediate piston
-cracked o-ring bleeds off intermediate apply pressure, preventing 2nd gear clutches from engaging
-forward clutches and intermediate band take all the 2nd gear abuse without intermediate clutches applied, and all of the above burn up
-constant forward clutch slip causes fluid to overheat
-clutch slip combined with 3000rpm stall converter makes it stall to 3500 out of boost and makes me think Circle-D sent the wrong converter...still wondering about that one
How's that sound?
Old Jul 19, 2011 | 01:53 PM
  #102
slow67's Avatar
Gingervitis Addict
Personally I'd ditch the kolene steels...go with stock Borg Warner High Energy clutches and stock steels. They are good to over 1200ish hp with the right builder.
Problem with kolene steels are they slide too much, instead of gripping.
Old Jul 20, 2011 | 02:29 AM
  #103
smokeshow's Avatar
Seems like people are endlessly divided on how to build a transmission.
Old Jul 20, 2011 | 01:40 PM
  #104
slow67's Avatar
Gingervitis Addict
LOL. Jake (Jake's Performance) taught me what I know. His knowledge comes from first hand experience.
Old Jul 20, 2011 | 06:53 PM
  #105
Jake's Performance's Avatar
FormerVendor
First hand experience that works....
https://www.performancetrucks.net/fo...s-what-482815/
Old Jul 20, 2011 | 10:49 PM
  #106
smokeshow's Avatar
Another carnage report...
I asked the dude who is helping me with the transmission about that...he agrees that the stock clutches are just as good as the reds. But only until the fluid heats up. After that the red altos show their ability over the stockers.
My interpretation of this is that the reds maintain a higher coefficient of static friction under the added load of a race application, which heats up the transmission fluid a lot more. Nobody would put them in their transmissions, much less manufacture those clutches if they were utterly useless
Old Jul 20, 2011 | 11:02 PM
  #107
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
There have been a lot of crappy performance parts made in the past so that line of logic is flawed...
Vince likes the stock BW clutches...
Old Jul 20, 2011 | 11:31 PM
  #108
smokeshow's Avatar
That is true, no argument there...I have seen my fair share of asinine "performance" parts. But I doubt the engineers down at Alto are a bunch of lumbering ogres who slap **** together and send it out to be used in high-power, high-abuse applications.
Bottom line is there is nothing to lose with going with the aftermarket clutches, only to gain.
Old Jul 21, 2011 | 06:18 AM
  #109
FormerVendor
It sounds like you're the expert and have it covered.
Old Jul 21, 2011 | 10:23 AM
  #110
smokeshow's Avatar
I certainly don't proclaim to be an expert. But as I said before, no two people I have talked to about this have agreed on what the problem was or how it should have been fixed. Someone saying I should have done different is really no surprise.
