brake system issues after gear swap...
Old 07-04-2010, 12:50 PM
14 Second Truck Club
fastgmc53's Avatar
Default brake system issues after gear swap...
I know these issues are all over this forum so I hope somebody can help me out..... I have an 04 gmc 2wd I just put 4.11's abd truetrac in it and since I fired it up I have had the service brake system issue. I have hp tuners and have since tuned it and speedo is dead on per gps. I bled the rear brakes to day and still gettin codes.. says wheel speed mismatch, and that both front wheel sensors are missing....... but when I clear the codes even with the truck ignition on nut running they pop right back up before the truck even starts..... also If I unplug one of the sensors is shows that that sensor has an open circuit so it is communicating with it. I cant disable the codes with HP tuners already looked. abs module doesn't do anything just feels like my brakes are gone when I stop. just hoping somebody else has fixed this since I can read the codes and all.....
Old 07-04-2010, 05:05 PM
JoeyGC5's Avatar
Do you have power to the sensors? You can get false feedback from the pcm input supplying a source and not having an actual supply voltage on the sensor.
Old 07-04-2010, 06:50 PM
fastgmc53's Avatar
I havent checked that.... the truck was fine then I pulled the rear out geared it and put it back in and have had te problem since......
Old 07-06-2010, 04:55 PM
fastgmc53's Avatar
ideas??
Old 07-08-2010, 08:45 AM
fastgmc53's Avatar
come on guys I really need to figure this out it's driving me crazy
Old 07-08-2010, 03:36 PM
fastgmc53's Avatar
bled all 4 corners... no air in it. can hp tuners not clear brake codes???? I try over and over to clear codes with just the ignition on and they still pop right back up before I even start the truck..... keep gettin
Brake] C0238 - Wheel Speed Mismatch (History)
[Brake] C0291 - (History)
[Brake] C0226 - LF Wheel Speed Signal Missing (History)
[Brake] C0222 - RF Wheel Speed Signal Missing (History)
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1096 - Loss of Communications with IPC (History) (Immature)
[HUD] U1000 - Class 2 Communication Malfunction (History) (Immature)
[HVAC] B0418 - (History) (Immature)
[HVAC] B0263 - (History) (Immature)
the HUD one just started today....wtf I dont even have it!!
Hvac started yesterday but no issues!!! this is really pissin me off
Old 07-09-2010, 08:18 AM
fastgmc53's Avatar
could it be that since hp tuners will only reset the drivetrain codes that I will have to have the stealership reset my brake codes.... I did drive the truck before I tuned it for the gears
Old 07-09-2010, 12:14 PM
PT's Slowest Truck
budhayes3's Avatar
Try disconnecting the battery for a few minutes to see if the codes clear...pretty sure that HPTuners and EFILive will only do engine codes, but I'm not 100% sure.
Old 08-13-2010, 03:34 PM
fastgmc53's Avatar
ides guys??? still having probs...... I have read about air in the abs module??? no abs light just the parking brake light and if i push it then it flashes 3 times and stays on again
Old 08-17-2010, 04:18 PM
fastgmc53's Avatar
bump..
Quick Reply: brake system issues after gear swap...
