Blew up the 10 bolt.... again...
Old Sep 29, 2009 | 07:59 PM
Turbo 6.0's Avatar
Default Blew up the 10 bolt.... again...
So I grenaded my 10 bolt again and am looking to upgrade. I'm not sure what my options are though. I don't have the cash for a 9" swap so I am looking for a 14 bolt that will bolt in. I have disc brakes in the rear and would be willing to swap over to drums if I have to. Any suggestions? How far can you take a 10 bolt with the right parts?
Old Sep 29, 2009 | 08:12 PM
nonnieselman's Avatar
What exactly did you break?
Old Sep 30, 2009 | 12:42 AM
budhayes3's Avatar
PT's Slowest Truck
The 14 bolt from the later SS's and Vortec Max's will bolt in...I believe that they are drum brakes but you mentioned that's not a problem. They already have the 6 lug axles...
Old Sep 30, 2009 | 08:45 AM
Turbo 6.0's Avatar
The carrier housing cracked and the ring and pinion gears were chipped and just generaly worn down.
Old Sep 30, 2009 | 08:47 AM
Turbo 6.0's Avatar
That's what I've been told in the past but I am having a hard time locating one.
Old Sep 30, 2009 | 11:10 AM
dang, what housing was it?
Old Sep 30, 2009 | 12:04 PM
shakesvho's Avatar
you will find them in the 05 up vho, the 04 had a 10 bolt
this is mine on my 05 vho, i'm doing 505 hp and no problems
Old Oct 3, 2009 | 09:49 AM
Turbo 6.0's Avatar
Thanks for the info and that is a sick setup you got there.
Old Oct 3, 2009 | 01:08 PM
fastnblu's Avatar
Billy, were any 14 bolts configured w/. 6lugs & discs?
Turbo 6.0, 525RWHP/ 575RWTQ was all it took to crack a housing? What were u doin at the time it broke? Normal drivin or abusin the daylights out of it?
Old Oct 3, 2009 | 03:40 PM
TURBHOE's Avatar
what diff were you running? i have a detroit locker in mine and it has taken alot of abuse. although i have broken 2 stock axle shafts. but i wiegh over 6000lbs and seemd to be making alot of power.
note: the last axle that broke seems to have slapped around and crack the bearing seat of the detroit. but the first time it broke it didn't hurt it.
