Best Proportioning Valve for Drum to Disc install.
Old Oct 13, 2015 | 04:07 PM
willhorne22's Avatar
Default Best Proportioning Valve for Drum to Disc install.
I've looked and I've searched, and cant find any straight answer on which specific proportioning valve would fit and work perfect on an 06 silverado rear disc setup. If some one can just give me a link to one they have used or like and know its the right threads for GM brake lines I would really appreciate it.
Thanks!
Old Oct 13, 2015 | 11:26 PM
Wolftrk99's Avatar
Ummm, do believe the abs module serves as proportionong valve.... Could be wrong but i havent seen a proportioning valve on these trucks..
Old Oct 14, 2015 | 07:19 AM
Every Tahoe I've seen that had disc brakes in the rear had a factory one? I thought I read several times if you do the swap you need one because you can lock your rear wheels up easy.
Old Oct 14, 2015 | 08:53 AM
Wolftrk99's Avatar
Older OBS tahoes, havent seen newer ones with it, could be wrong though
Old Oct 15, 2015 | 12:47 AM
1FastBrick's Avatar
Custm2500's Rude Friend
When you swap from drum to disk you would need a manual type proportioning valve so that you can adjust as needed.
Swap the master and you won't need one. Use one from an earlier style truck with 4 wheel disc.
The ABS module only controls the ABS function.
Old Oct 15, 2015 | 07:49 AM
So if I do the Hydro Boost swap, and take the booster and the master (as long as the rear has disc) I wont need the proportioning valve? I see this factory valve in like every 99-06 Tahoe at the salvage yard. ACDELCO 21998447
Old Oct 15, 2015 | 08:38 AM
Wolftrk99's Avatar
I stand corrected, even saw one yesterday... Is it just the tahoes that have the proportioning valve??? It had rear disc also... Know my truck, my boys 2000 tahoe, my old 02 suburban, and my old 02 avalanche didnt hve a proportioning valve....
Old Oct 15, 2015 | 09:12 AM
George C....'s Avatar
Formerly ScreamingL
On my 2010 it had drums and i swapped to disks...didnt use any proportional valve...i dont have no issues with rear lock up
Old Oct 15, 2015 | 10:09 AM
Atomic's Avatar
I have a gauge for that
I put Tahoe rear brakes on my truck that originally had 4 wheel disc and it does engage the rear brakes sooner/harder which makes the rear kick out on hard braking. Need to install a proportioning valve, just haven't got around to it...
Old Oct 15, 2015 | 10:33 AM
smokeshow's Avatar
Mod with training wheels
So now we know the real reason you spun out on the highway in the rain....go ahead, blame the radials!!
