Bad True Trac symptoms?
Old Mar 10, 2012 | 11:51 AM
brandon6.0's Avatar
Default Bad True Trac symptoms?
hey guys what are some symptoms of a bad true trac? I have been noticing a vibration still at higher speeds when i lift off the gas after a good kick down launch. I have even noticed that it seems to be wheel hopping when turning but only on the passenger side tire. I left marks in the road that showed it only coming from the passenger side.
I know the true trac is supposed to slip when turning but should it be doing this? I seem to notice it more and more. What yall think?
Old Mar 10, 2012 | 01:57 PM
smokeshow's Avatar
Mod with training wheels
Doesn't sound good. Pretty easy to pull the cover and inspect, I would start there. Check the bottom of the housing for debris.
Old Mar 11, 2012 | 08:08 AM
TXSZ66AVLANCHE's Avatar
I had wheel lock on mine, I did install non synthetic when it was installed, Ron recommended a different oil grade (don't remember type) and it fixed the problem.
Old Mar 12, 2012 | 12:31 PM
brandon6.0's Avatar
Well i took it out yesterday had a guy who wanted to try me out with a 4.8. When we left from a dig i ran it up to 90+ before i let off. It had a very bad rumble type vibration. It didnt smooth out till it got back down to 40 mph. I can tell its coming from the rearend. Felt like i damn near broke it on that pass.
Been chasing this vibration for so long about ready to just run it till the damn problem breaks. THin i will know what it was.
Old Jan 10, 2013 | 05:39 PM
Ford_Assassin's Avatar
Come Get Some!!
Update?
Old Jan 10, 2013 | 09:13 PM
brandon6.0's Avatar
Yeah found out I had a bad yoke. Replaced it and vibration stopped. Thank god. Is got so bad it cracked my trans on the side of the bell housing.
Old Jan 10, 2013 | 10:13 PM
dmelvin's Avatar
I chased a similar problem for nearly 2 months. Took me 4 extension housings before I finally swapped the driveshaft and yolk.
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Chevy305
Sep 28, 2015 09:21 PM
