Bad Symptoms
Old Jun 6, 2011 | 10:52 PM
guero68's Avatar
Default Bad Symptoms
Ok, well my Silvy is putting down some power and i think the trans is roasted 9200mi yess 9200mi the stealership will not touch it with all the mods.
Question is: I was at a light punched the skinny pedal down and I think i roasted the trans. At regualr throttle 1st gear now holds to about 4500+rpm before it shifts the rest of the shifting seems to be fine...Any Ideas
Thanks for the help
Old Jun 7, 2011 | 12:23 AM
08Silveradojp's Avatar
Thanks for the help
when i burned my gears... it just didnt shift out of first the gears were toasted for sure haha. but i dont know about yours go to the stealership and find somebody who will do it on the side thats what i did
Old Jun 7, 2011 | 12:42 AM
guero68's Avatar
so i guess my feeling is right...toasted tranny...thanks....might just go with a FLT or PB trans..
Old Jun 7, 2011 | 05:43 AM
Vince B's Avatar
Before going and throwing a trans at your truck I would look at a couple things first. I would suggest putting some kind of scan tool on your truck that allows you to view transmission data. Look for a couple things here. First would be if you are getting any transmission codes. Second would be if the computer is commanding the shift when this happens. If the command is there way before it shifts then I would suspect a band failure. Look at the shift solenoid data. You will be looking at the "A" solenoid to turn off or the scan tool might call this solenoid the "1-2" solenoid. If the command is not there then I would be looking other things like a mass air flow sensor. Keep in mind the trans is only going to do what the computer tells it to do. If the command is there then I would suspect either a cracked plastic 1-2 accumulator piston or a 2-4 band that is failing. Hope this helps and let us know what you find. Vince
Old Jun 7, 2011 | 01:16 PM
guero68's Avatar
ok, later on will be getting the system scanned for any codes...I dont know what else to think of than a failing trans....making about 550hp at 10psi of boost..waiting to have nelson call me for a date on a dyno tune...
Old Jun 7, 2011 | 02:57 PM
guero68's Avatar
Drove the truck still holding 1st gear to about 4k if i let off the gas it will goin in at 3k
Old Jun 7, 2011 | 03:52 PM
chevrolet all the way's Avatar
whats the truck and mods?
Old Jun 7, 2011 | 07:16 PM
guero68's Avatar
5.3 tvs1900 10.5lbs boost meth injection 224/230XER 114lsa cam 1.7 crane quick lift rockers arh 1 7/8 headers dod delete....that should it
Old Jun 7, 2011 | 07:56 PM
TIM Z's Avatar
11 sec. Truck Mod
Better put an 80E in that badboy and get it over with.
Old Jun 7, 2011 | 08:12 PM
Swerve7rpm2000's Avatar
X2
