backspacing on 15" wheels
Old Nov 6, 2007 | 09:35 AM
bluecajun5.3's Avatar
11 Second Truck Club
Originally Posted by slowprocess
On Bogarts, everyone is going with a 6.5" backspacing on these trucks. That's what backspacing I'm using for those wheels when I order them next month.
For reference, using The Breeze's wheel setup, looks exactly like where I want it to come out to.
just remember that's a 16" wheel.
Old Nov 6, 2007 | 10:19 AM
slowprocess's Avatar
Eh, that's right.....well should be the same on the 15s.......check out Txsqueeze4.8 bogarts 15x10 with 6.5" backspacing I might would even try to do a 6.75" and it should be pretty spot on.
Old Nov 6, 2007 | 10:30 AM
Honestly....I'm just thinking about going with a set of 6 lug to 5 lug(5x4.5) adaptor plates(1.75" thickness) and going with a set of weld draglites with a 7.5 backspacing for track use only. I don't think it would be a problem running them about 5 times a month. Anybody see any problem with that type setup?
Old Nov 6, 2007 | 05:43 PM
txsqueez has a drum rear end though. lot more clearance than the disc.
Old Nov 6, 2007 | 08:31 PM
SnakeOiler's Avatar
i'm talking about the edge of the rim that's against the truck side.
see the bolt that atatches to the calliper, there is a 1" gap between the bolt and the rim. so really, you could only widen this stock 16x7 rim roughly 3/4". i can only imagin how much work it would take for a 15" rim with more backspacing to clearance.
Pictures say a thousand words, thanks. I understand now. That's the brake line bolt, makes more sense than the caliper bolt (which is something else). Best thing would be to find some other caliper that could be used.
Old Nov 7, 2007 | 07:10 AM
I'm running a 15x10 with a 4.5" backspacing on my truck. I shaved the calipers, but there is plenty of room for more backspacing.........Does that help any, because I'm fresh out of helpful posts? ALso, it sticks out an unbelievable amount. Fossil is running a set of 15s with about 6-6.25 backspacing on his truck as well.
Old Nov 7, 2007 | 08:43 AM
53bowtie's Avatar
looks like youll just have to convert discs to drums......
Old Nov 19, 2007 | 02:48 AM
does fossil have any pics on here?
after looking into this more, my stock 16x7 rim has +31 off set and 5.2" BS.
so with having 1" between the rim and the bolt to play with, i think i could do a 15x10 with 6" BS.
Old Nov 19, 2007 | 12:47 PM
Superado's Avatar
just ground mine down for 15" wheels...mine are 15x10 w/ 5" bs...work fine...if I could've found more bs in an off the shelf wheel I prolly would have looked at those, but these are only $66.95 ea from Summit...
Old Nov 19, 2007 | 03:06 PM
Originally Posted by Superado
just ground mine down for 15" wheels...mine are 15x10 w/ 5" bs...work fine...if I could've found more bs in an off the shelf wheel I prolly would have looked at those, but these are only $6x.00 ea from Summit...
they're the steel ones right? i know the ones your talking about. how heavy are they? i'd like to see some pics of the inside and outside if you have any.
