axle rap?
Old Nov 22, 2005 | 08:28 PM
stone150's Avatar
Default axle rap?
when i get in slippery situations and both tires start spinning i hear this slapping noise, it is kind of scarry, my old truck never did it. i love fishtailing on wet streets but it does it alot, is this just my overload leafs rapping up and "slapping " the other springs? does this cause any damage?
Old Nov 23, 2005 | 11:08 AM
stone150's Avatar
some on has go to know?
Old Nov 23, 2005 | 11:12 AM
TG02Z71's Avatar
They all do that to some extent. I think what your hearing is the lowest helper spring slapping. My old 2000 did the same thing, they put the rubber bumper pads in there and it got allot quieter but never went all the way away.
Old Nov 24, 2005 | 03:11 PM
hog's Avatar
hog
GM actually makes little rubber wedges that are driven in between the leaf springs of teh truck. The spring wrap you are describing isnt harming anything, but it can develop into wheelhop as the tire searches fro traction.
Hog
Old Nov 26, 2005 | 01:28 AM
stone150's Avatar
can this be fixed with trac bars, also G80 question, do they have a tendency to not unlock? tonight i was at a stop light and when i went i spun the tires due to the wet road and i just let them spin till they got traction then as i med the turn and truc vibrated a little, then i went strait for 20 feet and turned again and same thing then stait and another turn, then i put it in neutral and tuned again and it hasn't doen it again, every time it vibrated it hadn't gotten over 10mph since i spun them.
Old Nov 26, 2005 | 09:27 AM
TXsilverado's Avatar
i think its suposed to unlock at 20mph but mine dosent. mine didnt want to come loose once. a hard right turn got it to unlock.
Old Nov 26, 2005 | 10:55 AM
stone150's Avatar
yeah it just seemed like it didn't want to unlock never had that happen before but never really have put it to the test like that. oh well
Old Dec 1, 2005 | 12:54 AM
hog's Avatar
hog
These locking difs are designed to unlock above a certain speed.
Hog
Old Dec 1, 2005 | 10:59 AM
Mort's Avatar
Cool
The G80 is designed to not lock up after 20 mph and to work like an open differential. It has a pawl that engages due to centrifugal force and keeps the differential from locking up after 20 mph. If you lock it up by spinning the tires below 20 mph it will likely stay locked up until you back the pressure off of it. If you enter a corner with the differential locked it will likely stay locked until you start to exit the corner due to the pressure held through the differential by the different speeds the wheels are travelling through the corner.
Old Dec 3, 2005 | 08:25 PM
hog's Avatar
hog
hanks fro clearing that up Mort, I thought they would release after 20 mph, but from what you are saying, they will stay engaged until the load is reelased.
i wonder why some of them diengage while doing burnouts at teh dragstrip in the burnout boxes?? Maybe just worn units.
peace
Hog
