Awesome Gear Ratio Calculator
Old Aug 7, 2012 | 11:04 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Awesome Gear Ratio Calculator
I've never found one this in-depth before. It's really nice since you can compare two different setups side by side. I just selected the nvg249 tcase so it would compute the tcase as a 1:1 ratio.
Old Dec 6, 2012 | 01:26 PM
nonnieselman's Avatar
can you copy this into your post or something??
https://www.performancetrucks.net/fo...4/#post5034879
https://www.performancetrucks.net/fo...heet-rev-b-zip
Old Jul 3, 2014 | 06:14 PM
Jeff Wilson's Avatar
Default Speedometer Setup
Hey 1slow01Z71,
Thanks for the post. We're doing a TH350 to 700R4 transmission swap in a 72 Chevy long bed and I was looking for info to help us with converting the speedo gears (which normally is just quick division), but the 4:56 gears have been swapped out for a set of 3:73s.
You're right, this calculator is by far the most detailed I've seen and was very helpful with the conversion. Thanks again.
Oobray
Jun 13, 2022 03:38 AM
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Oct 5, 2015 06:46 AM
1979rs/z28
Aug 24, 2015 08:43 AM
