Auto Trac 4000 RPM Vibe?
Old Jun 17, 2007 | 11:39 AM
MonteCarlo31's Avatar
Default Auto Trac 4000 RPM Vibe?
Just noticed ther other day on dry pavement that auto 4wd was on and in any gear at 4000+ RPM there was a surge release surge release type deal going on. almost like a A/C compressor cycling if that makes sense. The truck has probably seen 4000+ RPM in the last 20K miles maybe 4 times. Truck is a 2006 Silverado 5.3 4L60E 3.42 gears w/ 45K miles. Anyone ever notice this? Stock truck running a tune and 33x11.5x17 tires. Could this be a front u joint going out?
Old Jun 17, 2007 | 12:09 PM
It would be a good idea to check both front and back,just to make sure.But yes,I seen some front ones cause that problem before.
Old Jun 17, 2007 | 12:22 PM
Dock Rocker's Avatar
Could be a dent in your drive shaft, u-joints, may have thrown a weight off of you drive shaft. Dont know much about the autotrack but that is what I have seen with other AWD setups.
Old Jun 17, 2007 | 02:37 PM
I'll have to check it out, the truck does see a lot of jobsite driving so it's possible there is a chunk of mud on the shaft or I could have had it spinning in mud and slung the weight off as well. I'll check it out when I change the oil again. There is NO vibration in 2wd reguardless of RPM/Speed.
blown 04
Oct 2, 2015 07:33 AM
SLOPONY
11
Sep 24, 2015 02:47 PM
94f150
Sep 13, 2015 06:39 PM
Blwn99x
Sep 11, 2015 09:27 PM
chvy=power
Sep 8, 2015 11:06 AM
