ATF? Synthetic or not?
Old Apr 18, 2008 | 09:50 PM
closet red neck's Avatar
No synthetic......run just regular trans fluid. The syn will cause the clutches to slip some and in return build heat. Yes the syn fluid will take the heat better but the clutches don't like it. The regular trans fluid will allow the clutches to grab or lock up better than the syn..........in return shift harder. I did my own experiment with my truck, ran syn trans fluid in it when it was built, then slowly drained out the syn fluid overtime by pulling the plug and I could tell a difference in how it shifted overtime as the syn fluid disappeared. The truck always broke the tires loose in second but now it keeps the tires broke loose longer....?????.......and the third shift was definetly harder than before.
This is just what I experienced.........
Hope this helps.
James
Old Apr 18, 2008 | 09:51 PM
Whippled 496's Avatar
Mobil1 in the Allison since day one for me. Mobil1 in the crank case as well as the diff's too.
Old Apr 20, 2008 | 08:47 AM
03sierraslt's Avatar
Bump, anyone else? Guys running FLT's what are you running? Just any old Dex III?
Old Apr 20, 2008 | 09:01 AM
Who all removed the check ball in the end of there input shaft for firmer TQ lock up?
Old Apr 20, 2008 | 09:58 AM
CurtD's Avatar
10 Second Truck Club
If you have an FLT trans they remove the check ball...so there shouldn't be one to remove. I use ac delco dexron III.
Old Apr 20, 2008 | 11:08 AM
I dont have a FLT trans, I was just trying to decide whether to remove the ball or not. I imagine I will.
Old Apr 20, 2008 | 11:25 AM
truckmann's Avatar
I am using good old Dextron III in my FLT as recommended by the FLT guys.
Old Apr 20, 2008 | 12:43 PM
Cool, trans is coming the rest of the way apart shortly.
Old Apr 20, 2008 | 12:53 PM
tarinitup's Avatar
9 Second Truck Club
I Don't run synthetic on my FLT.
Old Apr 20, 2008 | 02:15 PM
wkdivr's Avatar
I'm running just regular DexronIII. Seems most people recommend using reg oil in these trans
