ATF? Synthetic or not?
No synthetic......run just regular trans fluid. The syn will cause the clutches to slip some and in return build heat. Yes the syn fluid will take the heat better but the clutches don't like it. The regular trans fluid will allow the clutches to grab or lock up better than the syn..........in return shift harder. I did my own experiment with my truck, ran syn trans fluid in it when it was built, then slowly drained out the syn fluid overtime by pulling the plug and I could tell a difference in how it shifted overtime as the syn fluid disappeared. The truck always broke the tires loose in second but now it keeps the tires broke loose longer....?????.......and the third shift was definetly harder than before.
This is just what I experienced.........
Hope this helps.
James
Hope this helps.
James
