Anyone tow with a PI stall???
Old Apr 26, 2006 | 03:42 PM
Last Call's Avatar
TOTM: January 2007
Default Anyone tow with a PI stall???
My tranny guy talked to PI today and they do not recommend any towing with a PI stall, like 300 pounds maximum.
What stall can I run with 4l80e and still tow something???
Old Apr 26, 2006 | 04:51 PM
Bish's Avatar
I tow a 5,000lb enclosed trailer regularly with my PI Vigilante 2400 in front of an FLT 4l60E. Probably 10,000 miles towing so far. Temps stay nice and low as long as I keep it from hunting (usually in 3). I also LOVE the triple disk lockup clutch.
When I was discussing my needs with Chuck @FLT, I told him about my towing and he discussed with PI and decided on the 2400. I think I could have gone 2600 but I think anything around 3000 is not so good IMO.
Old Apr 26, 2006 | 05:23 PM
Post
FYI.......FLT did not recommend a stall above 2600 for towing.
If this helps you choose a stall. I told them I would be hauling a 6,000lbs plus boat & trailer. They recommended the PI 10.5" 3 disc with both of their Sonnax servos and their recommended Transgo shift kit designed for towing and track use. Chuck at FLT said it would keep the rpm's in the 2400-2600 range.
Jim
Old Apr 26, 2006 | 09:34 PM
Last Call's Avatar
TOTM: January 2007
Thats wierd. i called Precision industries and they recommend no towing for there triple disk lock up converters.
I think I may just keep the stock stall.
Old Apr 26, 2006 | 10:03 PM
Post
Just quoting what Chuck at FLT told me. I too am torn on what will work and what will not.
I keep hearing too many different stories! If PI told you not to tow with it, then I assume they know what they are talking about.
I don't know what to use either at this point. I know I want something more than the O.E. stall though.
It will just take a bit more research!
I'm about to PM FLT and see why he recommended that stall and why PI themselves say not too.
Jim
Old Apr 27, 2006 | 07:18 PM
TIM Z's Avatar
11 sec. Truck Mod
2800 P I stall triple disc, Tow my car hauler and my old ford 8N tractor NO problem!! This stall is heavy duty, THANKS ZIPPY AND T.J.!!
jtphelps289
Sep 11, 2015 06:37 PM
GM1697
Sep 9, 2015 10:31 PM
tgui
Sep 9, 2015 04:55 PM
GM1697
Sep 9, 2015 01:52 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
