Anyone Install A Differential Cover Drain Plug
Old May 14, 2009 | 01:44 PM
therock's Avatar
Default Anyone Install A Differential Cover Drain Plug
I have access to a machine shop and would like to add a drain plug to my diff cover and am wondering if you guys have done it. Pics?
I'm going to change up to 3.73 from 3.42's and will buy a stock cover and have it ready at the change.
Old May 14, 2009 | 10:42 PM
slow.8's Avatar
its already got one, check underneath the housing.
Old May 14, 2009 | 10:54 PM
BLUES MAN's Avatar
The House is Rockin'
like he said there already is 1, but if you want a plug get a aftermarket chrome cover. mine came with a plug and a stainless plug bolt with a magnet on the end. bad pic but heres mine installed.
Old May 15, 2009 | 04:45 AM
therock's Avatar
I already did. No plug on mine.
Don't want no chrome. Just a stock cover with a plug.
Old May 15, 2009 | 06:00 AM
Parke10's Avatar
from my understandin hardly any of them came with drain plugs, if u got one you were a lucky one.
Refering tho this thread
http://www.gmfullsize.com/forum/show...ght=drain+plug
Old May 15, 2009 | 11:25 AM
slow.8's Avatar
huh, well.. sorry about the misinfo.
Old May 15, 2009 | 12:53 PM
GMCtrk's Avatar
I got a plug haha you all got screwed
Old May 15, 2009 | 01:35 PM
nonnieselman's Avatar
mine has a plug also.. found it after the 3rd time i changed fluid..
Goin to try it when i put the Girdle on
Old May 15, 2009 | 04:01 PM
budhayes3's Avatar
PT's Slowest Truck
I think that the earlier ones had plugs, mine does. I also have a TA rear diff girdle which has it's own plug also, so I can drain twice as fast lol I'd recommend the TA cover/girdle, it has pre-load bolts which apply 5 ft/lb of pressure on the bearing caps and helps to strengthen the rear. TA also sells rear bearing cap stud kits that are stronger than the factory bolts.
Old May 15, 2009 | 05:05 PM
Parke10's Avatar
you have any problems with it coming loose and leaking , i heard those have to be re checked like every few weeks because they like to come loose.
