Anyone done research on T56 with 4wd?
Old Dec 24, 2005 | 06:07 PM
thunder550's Avatar
High on diesel fumes
Default Anyone done research on T56 with 4wd?
I remember seeing something about having to replace the output shaft or have a custom tailhousing made....anyone ever done serious research and figured out what needs to be done to mate a T56 to a transfer case?
Old Dec 24, 2005 | 08:23 PM
thunder550's Avatar
nm did a search, doesn't look like there's any solution that wouldn't cost an arm and a leg.
Old Dec 25, 2005 | 12:30 AM
spitfire2332's Avatar
it sure would be nice if it didnt cost an arm and an ******* wouldnt it?
manual > auto... maybe in the GMT-900s they'll have a decent 6-speed that mates to a x-case.
Old Dec 25, 2005 | 01:11 AM
thunder550's Avatar
yeah if i had a few grand to throw at it maybe i could figure something out....ill keep hoping that they come out with something decent that's x-fer case compatible.
Old Dec 25, 2005 | 09:06 AM
vanillagorilla's Avatar
Why is it so hard? A custom output shaft, an adaptor plate or something and 2 driveshafts? Right?
Old Dec 25, 2005 | 09:30 AM
thunder550's Avatar
Custom output shaft screams $$$$ to me. Are they real expensive?
Old Dec 25, 2005 | 09:43 AM
NoChrome's Avatar
I know the HD's have the option for 6 spds, did you try looking donw that route?
Old Dec 25, 2005 | 10:34 AM
thunder550's Avatar
Not yet....I need to figure out exactly what is wrong I guess before I decide what route to go. I can either do a 4L65E, have the 4L60E rebuilt again, or try for the 6 speed swap. Anyone have any info on the T56 vs the 6-speed from the HD's? Are they the same size? I looked into the 80E swap at one time and just the supporting hardware was almost as expensive as the tranny itself, I'd like to find something that is a direct or near-direct swap.
Old Dec 25, 2005 | 11:10 AM
performance wise the 6-speed they make for our trucks sucks. 1st gear is a super low gear making it pretty much useless. And on top of that I dont think its a very strong transmission
Old Dec 25, 2005 | 11:13 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Thunder in an 80e all you need to do is put a shift kit in it and it will be fine for what you do. Im only going to do a shift kti and clutches in mine ot put behind the new motor.
