Anyone 05 Z71 lowering knowledge would be appreciated
Thats about where Im at with my heights. Whered you get your stuff from?
@1 fastsilverado your stance looks real slick also, sick truck.
Thanks for all the info everyone.
The purple keys are actually the stock HD keys, so if you can find a guy with an HD that wants to go higher, you might be able to trade your stock keys for his (the stock half-ton keys will work as a leveling key for the HDs).
I got ~3/4 from mine too (2005 Z71)
I did shackles and hangars but I'd recommend just removing the rear lift blocks and using lowering shackles. In the front 2" spindles and a little de-twist of the torsions, check and you probably won't need to change keys at all.
My stock fender heights were 36.5" front, and 38.5" rear, and the current height is about 32.75" all the way around. If you want it to sit a bit higher, you could easily not de-crank the front as much as I did, and just run shackles and no blocks in the rear.
Here's how mine sat with just shackles and no blocks in the rear (with the front still where it is now).
http://www.flickr.com/photos/danvala...7625561764765/
And yeah, I'm about 40 minutes outside of Philly.
My current set up consists of Belltech lowering keys (same concept as purple keys), Belltech 2" shackles, lift blocks removed, and spring clamps...tires are about 31" tall (285/50-20 summer, 275/70-16 winter...usually, haven't put my winter wheels on yet this year)
I moved this to the GM Drivetrain and Suspension section btw, you should get more hits here
