Anybody strip a converter bolt?
Old Dec 16, 2006 | 10:27 AM
14 Second Truck Club
I'm fixing to try and get some vice grips around it.
Old Dec 16, 2006 | 12:08 PM
Bolt is officially stripped. Got the other one out though. Vise grips didn't work. I even tried hammering the hex-bit in, thought I almost had it and it stripped.
Old Dec 16, 2006 | 03:31 PM
I borrowed my g/f's dad's air compressor and air chisel. It barely made an indention on it and I've been at it for 30 min and basically rounded off 2 chisels already.
Old Dec 16, 2006 | 03:36 PM
twobit's Avatar
try a regular chisel and a big f"n hammer. Sharpen the chisel with a grinder every few minutes. I used an air chisel on the ball joint rivets and it didnt do much either. I then used a fat chisel and a big hammer and that seemed to work better. Its gonna be hard to do being your in such a tight place.
Old Dec 16, 2006 | 03:55 PM
Thanks Clint, I'll try it.
Old Dec 16, 2006 | 04:00 PM
Do ya'll think it would hard to pull the motor out with the tranny?
Old Dec 16, 2006 | 04:37 PM
onebadrubi's Avatar
can be done. I think someone did a write up on that not to long ago.
Old Dec 16, 2006 | 04:54 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
In a 2wd its cake, you can do it pretty easily just need an extra person to help guide the trans once you get the engine off it mounts.
Old Dec 16, 2006 | 05:09 PM
FarmerBeau's Avatar
Sexy Party Mod
pm thunder550. I know he pulled his engine and tranny as one unit.
Old Dec 16, 2006 | 05:22 PM
BlackGMC's Avatar
Resident Retard
Use a SawZaw and just cut the head off of it then worry about it once it is out. If you don't have a SawZaw use a hack saw blade. Might take awhile thou....
